GlueFactoryBJJ
- Oct 15, 2015
Hi Everyone!
I sure hope you can help with this one...
For the record, I've been using FreeNAS for over 3 years (since 9.x, I'm currently on 11.2-U5(?)) and I haven't tried doing much other than basic NAS functionality. So, I would consider myself to be both a Unix and FreeNAS n00b, though I have both used and worked in the computer industry since the late 1980s (first computer was a TRS-80 with 4K(!) of RAM and a cassette tape drive storage).
It has worked very well through an upgrade from a SATA to LSI 9206-8i HBA upgrade (FreeNAS detected the drives were connected to the LSI card and configured the 6 x 4TB WD Red ZFS2 array without issue). The switch from USB stick (failing) to HDD and then from HDD to the current SanDisk 120GB SSD. The replacement of a bad 4TB WD Red drive (rebuilt the array without complaint). And even the addition of two additional WD RED drives added to the ZFS array, though I had to back up the array, add the new drives, put the old and 2 new 4TB WD Red drives into a 8 x 4TB WD Red ZFS2 array, and copy the data back to FreeNAS server.
The long and short is that it works well, if a bit on the slow side, which is why I am wanting to upgrade from the current dual core CPU to a (new for this system, but used) quad core.
Anyway, my initial server configuration (before the CPU upgrade), which has worked flawlessly (if slowly) until now, is:
AMD A6-5400 CPU
Gigabyte F2A88XM-D3H motherboard (for the 8x SATA ports and support for 4x DDR3 memory)
2 x 8GB DDR3 1333
1 x DVD player
1 x Sandisk 120GB SSD
LSI 9206-8i HBA
8 x 4TB WD Red HDD in a ZFS2 array (32TB total, 24TB net storage)
Generic Silverstone case
550W 80plus power supply
The only thing that I have done between the above flawlessly working (and no errors on the console before the upgrade) is change the CPU from the A6-5400 (dual core with integrated graphics) to an A8-6500 (quad core with integrated graphics, $20 delivered).
So far as I know I have not encrypted these drives...(?)
After the "upgrade" the system will not complete the boot process (see the attached pics).
There are 7 pics below and they are in the order they come up during boot.
Pic #1:
Pic #2:
Pic #3:
Pic #4:
Pic #5:
Pic #6:
Pic #7:
The pics represent any "pause points" in the boot process that I could take pics of. With the old processor, the entire boot process would only take a couple minutes. The last page represents a process loop. It displays a bunch of data, leaving the last screen where it pauses for ~30 seconds before trying again. I have left it here for hours and it continues the cycle.
Do I have to reinstall the OS to get this to work with this new CPU? I've never run across something like this, so I'm at a loss (as I am with just about anything Unix/Linux).
Any help would be appreciated! Please note that "get another CPU/Motherboard/memory/etc." won't help as I had a working system before and don't have the money for other hardware. This was old hardware I had at the time and it has worked well up until now. I still have the old CPU, but would like to see if there is anything I can do to get this new CPU working.
Thanks in advance!
Scott
PS. I REALLY need to get this array working again because, like a moron, I forgot to backup about 5TB of home videos I hadn't edited and uploaded to YouTube yet! I don't have any other copies of these videos! Yeah, I know. I DO know better!
AMD A6-5400 CPU
2 x 8GB DDR3 1333
1 x DVD player
LSI 9206-8i HBA
Pic #1:
Pic #2:
Pic #3:
Pic #4:
Pic #5:
Pic #6:
Pic #7:
Thanks in advance!
Scott
