Dirk
- May 23, 2016
Got a two disk Synology to backup the Freenass 11.3 media servers media.
Initially set up with a 4TB drive, installation of DSM 6.x (the latest) was fine, and a little thrashing around and Freenas transferred about a TB before drive went disks up with bad blocks.
So, start again with a WD datacenter 8tb drive which took two day to do a parity check. Everything stayed the same on the Freenas box.
Freenas side.........
An " rsync" user with same user name and password on Synology.
Synology side........
rsync enabled which created NetBackup share. User rsync added to share with full permission. ssh also enabled.
Freenas rsync task.......
Path to directory is pointing to the media directory on Freenas
User "rsync"
IP "Yada.yada.yada.yada"
Rsync mode "module"
Remote module "NetBackup"
Direction "push"
Hitting save results in a failed notification and suggests checking log. the only thing in the log downloaded is
"rsync: failed to connect to 192.168.0.30 (192.168.0.30): Connection refused (61)
rsync error: error in socket IO (code 10) at clientserver.c(127) [sender=3.1.3]"
From a shell on freenas I can ssh into the synology with rsync@192.168.0.30 and provide the password.
Since it already worked before, I'm at a loss as to what I'm missing.
Thanks
User "rsync"
Rsync mode "module"
Direction "push"
Thanks
