FreeNAS SMART versus Vendor SMART
GChuck
I posted a message on Sunday to which I received no responses so I'll repost with different parameters.
I received what appeared to be an SMART error message on one of my 4TB IronWolf drives which is in a RAID-Z2 pool. I read the "Hard Drive Troubleshooting Guide" here on the forum. I then ran the a smartctl short test on the drive and IDs 197 and 198 showed errors. I shut down the system and checked all the cables and their connections and then boot the system with the Seagate SeaTools diagnostic disk. I ran Seagate's Short test and long test and both passed.
Next I rebooted FreeNAS and did another smartctl short test which showed none of the ID 197 and 198 errors but did show and "ATA Error Count: 5" message followed by what appeared to be descriptions of the errors.
So I'm getting conflicting results from the smartctl command used in FreeNAS vs the SMART test used by Seagate. Without a failure in the Seagate SMART test which produces an RMA number, I cannot RMA the drive. But is the drive really going bad or is this some quirk in the FreeNAS smartctl program. I've include output from the smartctl programs in my original message which show the errors I'm seeing.
The drive appears to be working fine and the server is running as it should. What should I do???
Thank you
Greg ...
joeschmuck
Old Man
Post a screen capture of the Seagate Test and the Results.
Passing Short and Long tests is good and I suspect SMART shows that as well. My concern is Seagatye tools are looking at the summary value of the drive being okay. Yes the drive is okay, for now, but it is failing.
So post the screen captures or outputs and the output of the smartctl -a parameter.
GChuck
Joeschmuck, thank you for replying.
The output of the smartctl -a /dev/ada2 is displayed below. This smartctl output was run after I got the 197, 198 errors and had run both the SMART long and short tests. The SMART tests were run on both my FreeNAS system via the smartctl command and via the bootable SeaTools SMART tests. The output of the SeaTools SMART tests (both long and short) just said "PASSED". No other information was given.
If you need it, I also have the output of the smartctl tests which include the original SMART errors (197,198 etc).
I think what the smartctl output is telling me is that errors were found, but have been corrected. Not sure if this means the drive is failing or not. I have contacted Seagate but they appear reluctant to RMA the drive. The drive is only a little under 3 months in use.
I know the FreeNAS community appear to recommend the WD Red drives, but after WD sneaking SMR drives out to the unsuspecting public, I decided to go with the SeaGate IronWolf drives which I knew were CMR.
So please let me know if I should be worried about this drive. In the meantime, I think I'll do some more reading on what SMART really does and how it works.
Thanks for you help.
Greg ...
Model Family: Seagate IronWolf
Device Model: ST4000VN008-2DR166
Serial Number: ZGY7xxxx
LU WWN Device Id: 5 000c50 0c6a0dbbe
Firmware Version: SC60
User Capacity: 4,000,787,030,016 bytes [4.00 TB]
Rotation Rate: 5980 rpm
Form Factor: 3.5 inches
ATA Version is: ACS-3 T13/2161-D revision 5
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Fri Nov 13 07:43:23 2020 PST
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
data collection: ( 591) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 643) minutes.
Conveyance self-test routine
SCT capabilities: (0x50bd) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000f 084 064 044 Pre-fail Always - 230826740
3 Spin_Up_Time 0x0003 094 093 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 34
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 075 060 045 Pre-fail Always - 31071951
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 455 (198 88 0)
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 34
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 095 095 000 Old_age Always - 5
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0
189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 081 057 040 Old_age Always - 19 (Min/Max 17/19)
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 2
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 47
194 Temperature_Celsius 0x0022 019 043 000 Old_age Always - 19 (0 16 0 0 0)
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 455 (167 174 0)
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 10348167458
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 28674199407
SMART Error Log Version: 1
ATA Error Count: 5
CR = Command Register [HEX]
FR = Features Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Error 5 occurred at disk power-on lifetime: 403 hours (16 days + 19 hours)
ER ST SC SN CL CH DH
40 51 00 ff ff ff 0f Error: UNC at LBA = 0x0fffffff = 268435455
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
25 00 00 ff ff ff 4f 00 1d+07:10:37.235 READ DMA EXT
25 00 00 ff ff ff 4f 00 1d+07:10:34.255 READ DMA EXT
25 00 00 ff ff ff 4f 00 1d+07:10:31.295 READ DMA EXT
25 00 00 ff ff ff 4f 00 1d+07:10:28.314 READ DMA EXT
25 00 00 ff ff ff 4f 00 1d+07:10:25.388 READ DMA EXT
Error 4 occurred at disk power-on lifetime: 403 hours (16 days + 19 hours)
25 00 00 ff ff ff 4f 00 1d+07:10:25.387 READ DMA EXT
Error 3 occurred at disk power-on lifetime: 403 hours (16 days + 19 hours)
25 00 00 ff ff ff 4f 00 1d+07:10:25.386 READ DMA EXT
Error 2 occurred at disk power-on lifetime: 403 hours (16 days + 19 hours)
25 00 80 ff ff ff 4f 00 1d+07:10:25.386 READ DMA EXT
Error 1 occurred at disk power-on lifetime: 403 hours (16 days + 19 hours)
25 00 80 ff ff ff 4f 00 1d+07:10:25.385 READ DMA EXT
# 1 Short offline Completed without error 00% 443 -
# 2 Short offline Completed without error 00% 442 -
# 3 Short offline Completed without error 00% 436 -
# 4 Extended offline Completed without error 00% 415 -
# 5 Short offline Completed without error 00% 399 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
