FreeNAS freezing completely after trying to access pool using SMB, AFP, etc
I have this problem, when I tried to access files from FreeNAS over SMB, UI stopped working, all jails and everything just stopped working.
Server is visible on network scan, ports are open, but server is not responding anything.
Notice that this only happens when you try to access files over network. Also command line frozes. After hard reboot, it starts to work, but I can't access any file without it freezing completely.
What can be the cause?
I just backed up configuration, and I want to try reinstall OS. Is it good idea?
I'll be thankful for any help.
And after reboot with some time passed Web UI started running very sloow, can't log in.
My server was running fine almost a year, so no issues before.
D
dlavigne
Guest
Anything in /var/log/messages around the time of the freeze?
