CMDR Sweeper
- Jan 21, 2014
Hello, my FreeNAS box has for a while now been dropping it's connection on my Netgear GS724T 24 port switch.
It usually happens after 3-4 days where the FreeNAS disappears from the network, and the switch goes dark as if you had yanked the cable, but it is still connected.
If I change the port to one other of the 24 ports it will work again, but that port remains dead until I give the switch a reboot command.
This issue however is ONLY experienced with the FreeNAS box, the other devices, both Windows and Linux connected to the switch works fine with no issues.
I have had the same motherboard that is now used in the FreeNAS in a desktop before, hooked up to the same switch and it didn't exhibit the same symptoms under either Windows or Linux.
I have also tried updating the firmware on the switch to the latest, and it didn't change anything.
Only thing I haven't done is updating my FreeNAS box from 9.2.0 just yet due to the Active Directory problems that seems to be present, as I got that working on 9.2.0 at the moment.
In the Netgear Switch I get a "No energy detected" on that port so I would guess there is something related to shutting down the network interface to save power or something, can this feature be disabled?
The motherboard that FreeNAS uses with onboard networking is an ABIT IP35 Pro that has a Realtek card.
