TAC
- Feb 16, 2014
I have two volumes in my FreeNAS system, Data and Data1. I'm trying to figure out why when checking the Disk Reporting the 3 HDs in my z1 Data array run around 80% busy while the 6 HDs in my z2 Data1 array run mostly at 0% busy.
With all my jails on Data I did turn off each jail and found when I turned off the Plex media server the Disk Busy dropped to a few percent from about 80%. If no one is using the Plex server I see no reason for these loads.
Any suggestions on what to look at to see what's going on?
Thnx,
-TAC
p.s. the last scrub of Data took 62h4m (zero errors) and Data1 only took 7h28m (zero errors).
Thnx,
-TAC
