[FreeNAS 9 Plugin] MineOS suddenly won't start after reboot...
LWWz
Build FreeNAS-9.10.2-U1 (86c7ef5)
Platform Intel(R) Core(TM) i5-4690S CPU @ 3.20GHz
Memory 16231MB
It's been running for over a week through at least 2 reboots and today it decided to not restart after a reboot. Any suggestions?
Feb 19 12:42:24 freenas1 manage.py: [plugins.utils:91] Couldn't retrieve http://192.168.0.50/plugins/mineos/6/_s/status: HTTP Error 503: OK
Interestingly, it no longer shows up on the list of Plugins on the left tree view but does show up in the Jails and the Installed plugins:
https://www.dropbox.com/s/csyeenzt9i7lj7q/Screenshot 2017-02-19 12.48.49.png
P.S. My daughter will be home soon with a friend to play minecraft and if I've broken her server, there's gonna be hell to pay! ;)
Try unchecking the VIMAGE checkbox in your jail and/or manually assign a fixed IP address.
Jailer
Not strong, but bad
Can you manually start it from the CLI?
LWWz
It is manually assigned IP 192.168.0.51/24
Unchecking the VIMAGE box seems to have solved the problem!
Now I need to go read what that does! ;) Thanks for the help!
