freenas 9.3 stable 20150604 kdb error panic after upgrade
ShinobiX9X
After the last upgrade it stops booting with that message (see pic below)
I tried booting on previous releases but same problem.
I installed a new freenas on another usb, that boots, but it refuses to import volume, it gets an
error and reboots.
Any ideas what I should try?
many thanks
D
dlavigne
Guest
What error do you get when you try to import the pool?
ShinobiX9X
I do it trough t web ui, i just see : an error occured, and i have to wait , it reboots
if you give me the commands, i can try in shell and see what happens. :)
ShinobiX9X
this is a video when i did: zpool import FreeNAS: https://youtu.be/RmjkxoPJfQg
after thr reboot of the new freenas install, i get this in the bottom console of the webgui:
freenas zfsd: DevfsEvent::ReadLabel: /dev/ada0p1: Unable to extract pool GUID from vdev label data
That error with the GUID is normal for spare drives.
But the zpool import causing the crash is generally an indicator of your zpool being corrupted somehow. At this point your best bet is to recover from backup.
ShinobiX9X
Ai i only backed up important data, ill have to reinstall everything?
Verstuurd vanaf mijn Moto G met Tapatalk
