larynx
- Jul 8, 2014
I installed FreeNAS 9.3-BETA a little while back and yesterday I decided to upgrade to 9.3-STABLE so I ran through the upgrade process and it was hanging on the final phase (Installing freenas-pkg-tools) for about 2 hours so I decided to close the window and restart the machine. After the restart I tried the upgrade again and it worked, the machine then rebooted but when GRUB boots up it choose the FreeNAS-BETA entry instead of FreeNAS-STABLE.
I rebooted and selected the stable entry manually from GRUB and everything seems to be working fine but when I go to System->Boot the stable entry shows up as active and it's says "On Reboot, Now" (see image below) but when I reboot it selects the beta entry.
Should I change this manually in the GRUB configuration or should I be able to change it via the FreeNAS GUI?
Thanks
Thanks
