FreeNAS 8r7419 + AMD 64 - Nightly - NIC Selection problem
n9nu
I don't know if the new nightly (tonight) will have the same problem, however, the last two seem to have a problem with being able to select the primary network interface upon an initial installation.
You can select the first option (#1) to bring up which NIC you want to use (I have three to select from), however, it will not 'stick' or accept the value (1, 2 or 3 in my case). Pressing 'q' will return to the menu w/o saving anything.
Just FYI....will try and download the next nightly
Tim
joeschmuck
Old Man
Has this ever worked for you? If so, what version? If it did work and we have an idea of when, a ticket could be submitted stating the problem and that is did work at build zyx. This will help the Devs fix the problem quicker if they know it worked before.
Also, what hardware are you running. Maybe the NIC chipset isn't supported if it has never worked. What are the three options? And this is a real computer, not VMWare or something like it?
-Mark
