Hallo alle zusammen,
also habe nun nach Anweisung nochmals neu gestartet. Kein positives Ergebnis:
Mar 13 18:23:05 freenas newsyslog[1062]: logfile first created
Mar 13 18:23:05 freenas syslogd: kernel boot file is /boot/kernel/kernel
Mar 13 18:23:05 freenas kernel: Copyright (c) 1992-2011 The FreeBSD Project.
Mar 13 18:23:05 freenas kernel: Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
Mar 13 18:23:05 freenas kernel: The Regents of the University of California. All rights reserved.
Mar 13 18:23:05 freenas kernel: FreeBSD is a registered trademark of The FreeBSD Foundation.
Mar 13 18:23:05 freenas kernel: FreeBSD 8.2-RELEASE-p5 #0: Tue Jan 3 03:27:19 PST 2012
root@build.ixsystems.com:/build/home/gcooper/e2e-bld.RqwJtDXy/obj.i386/i386/build/home/gcooper/e2e-bld.RqwJtDXy/FreeBSD/src/sys/FREENAS.i386 i386
Mar 13 18:23:05 freenas kernel: Timecounter "i8254" frequency 1193182 Hz quality 0
Mar 13 18:23:05 freenas kernel: CPU: Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz (3436.41-MHz 686-class CPU)
Mar 13 18:23:05 freenas kernel: Origin = "GenuineIntel" Id = 0x206a7 Family = 6 Model = 2a Stepping = 7
Mar 13 18:23:05 freenas kernel: Features=0x783f3bf<FPU,VME,DE,PSE,TSC,MSR,MCE,CX8,APIC,MTRR,PGE,MCA,CMOV,PAT,PSE36,MMX,FXSR,SSE,SSE2>
Mar 13 18:23:05 freenas kernel: Features2=0x209<SSE3,MON,SSSE3>
Mar 13 18:23:05 freenas kernel: TSC: P-state invariant
Mar 13 18:23:05 freenas kernel: real memory = 536805376 (511 MB)
Mar 13 18:23:05 freenas kernel: avail memory = 510595072 (486 MB)
Mar 13 18:23:05 freenas kernel: kbd1 at kbdmux0
Mar 13 18:23:05 freenas kernel: cryptosoft0: <software crypto> on motherboard
Mar 13 18:23:05 freenas kernel: acpi0: <VBOX VBOXXSDT> on motherboard
Mar 13 18:23:05 freenas kernel: acpi0: [ITHREAD]
Mar 13 18:23:05 freenas kernel: acpi0: Power Button (fixed)
Mar 13 18:23:05 freenas kernel: acpi0: Sleep Button (fixed)
Mar 13 18:23:05 freenas kernel: Timecounter "ACPI-safe" frequency 3579545 Hz quality 850
Mar 13 18:23:05 freenas kernel: acpi_timer0: <32-bit timer at 3.579545MHz> port 0x4008-0x400b on acpi0
Mar 13 18:23:05 freenas kernel: pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
Mar 13 18:23:05 freenas kernel: pci0: <ACPI PCI bus> on pcib0
Mar 13 18:23:05 freenas kernel: isab0: <PCI-ISA bridge> at device 1.0 on pci0
Mar 13 18:23:05 freenas kernel: isa0: <ISA bus> on isab0
Mar 13 18:23:05 freenas kernel: atapci0: <Intel PIIX4 UDMA33 controller> port 0x1f0-0x1f7,0x3f6,0x170-0x177,0x376,0xd000-0xd00f at device 1.1 on pci0
Mar 13 18:23:05 freenas kernel: ata0: <ATA channel 0> on atapci0
Mar 13 18:23:05 freenas kernel: ata0: [ITHREAD]
Mar 13 18:23:05 freenas kernel: ata1: <ATA channel 1> on atapci0
Mar 13 18:23:05 freenas kernel: ata1: [ITHREAD]
Mar 13 18:23:05 freenas kernel: vgapci0: <VGA-compatible display> mem 0xe0000000-0xe0ffffff irq 11 at device 2.0 on pci0
Mar 13 18:23:05 freenas kernel: em0: <Intel(R) PRO/1000 Legacy Network Connection 1.0.3> port 0xd010-0xd017 mem 0xf0000000-0xf001ffff irq 10 at device 3.0 on pci0
Mar 13 18:23:05 freenas kernel: em0: [FILTER]
Mar 13 18:23:05 freenas kernel: em0: Ethernet address: 08:00:27:b1:a1:cd
Mar 13 18:23:05 freenas kernel: pci0: <base peripheral> at device 4.0 (no driver attached)
Mar 13 18:23:05 freenas kernel: pci0: <multimedia, audio> at device 5.0 (no driver attached)
Mar 13 18:23:05 freenas kernel: ohci0: <OHCI (generic) USB controller> mem 0xf0804000-0xf0804fff irq 11 at device 6.0 on pci0
Mar 13 18:23:05 freenas kernel: ohci0: [ITHREAD]
Mar 13 18:23:05 freenas kernel: usbus0: <OHCI (generic) USB controller> on ohci0
Mar 13 18:23:05 freenas kernel: pci0: <bridge> at device 7.0 (no driver attached)
Mar 13 18:23:05 freenas kernel: ehci0: <Intel 82801FB (ICH6) USB 2.0 controller> mem 0xf0805000-0xf0805fff irq 10 at device 11.0 on pci0
Mar 13 18:23:05 freenas kernel: ehci0: [ITHREAD]
Mar 13 18:23:05 freenas kernel: usbus1: EHCI version 1.0
Mar 13 18:23:05 freenas kernel: usbus1: <Intel 82801FB (ICH6) USB 2.0 controller> on ehci0
Mar 13 18:23:05 freenas kernel: acpi_acad0: <AC Adapter> on acpi0
Mar 13 18:23:05 freenas kernel: atkbdc0: <Keyboard controller (i8042)> port 0x60,0x64 irq 1 on acpi0
Mar 13 18:23:05 freenas kernel: atkbd0: <AT Keyboard> irq 1 on atkbdc0
Mar 13 18:23:05 freenas kernel: kbd0 at atkbd0
Mar 13 18:23:05 freenas kernel: atkbd0: [GIANT-LOCKED]
Mar 13 18:23:05 freenas kernel: atkbd0: [ITHREAD]
Mar 13 18:23:05 freenas kernel: psm0: <PS/2 Mouse> irq 12 on atkbdc0
Mar 13 18:23:05 freenas kernel: psm0: [GIANT-LOCKED]
Mar 13 18:23:05 freenas kernel: psm0: [ITHREAD]
Mar 13 18:23:05 freenas kernel: psm0: model IntelliMouse Explorer, device ID 4
Mar 13 18:23:05 freenas kernel: pmtimer0 on isa0
Mar 13 18:23:05 freenas kernel: orm0: <ISA Option ROMs> at iomem 0xc0000-0xc8fff,0xe2000-0xe6fff pnpid ORM0000 on isa0
Mar 13 18:23:05 freenas kernel: sc0: <System console> at flags 0x100 on isa0
Mar 13 18:23:05 freenas kernel: sc0: VGA <16 virtual consoles, flags=0x300>
Mar 13 18:23:05 freenas kernel: vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0
Mar 13 18:23:05 freenas kernel: atrtc0: <AT Real Time Clock> at port 0x70 irq 8 on isa0
Mar 13 18:23:05 freenas kernel: ppc0: parallel port not found.
Mar 13 18:23:05 freenas kernel: fuse4bsd: version 0.3.9-pre1, FUSE ABI 7.8
Mar 13 18:23:05 freenas kernel: Timecounter "TSC" frequency 3436414283 Hz quality 800
Mar 13 18:23:05 freenas kernel: Timecounters tick every 10.000 msec
Mar 13 18:23:05 freenas kernel: usbus0: 12Mbps Full Speed USB v1.0
Mar 13 18:23:05 freenas kernel: usbus1: 480Mbps High Speed USB v2.0
Mar 13 18:23:05 freenas kernel: ugen0.1: <Apple> at usbus0
Mar 13 18:23:05 freenas kernel: uhub0: <Apple OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus0
Mar 13 18:23:05 freenas kernel: ugen1.1: <Intel> at usbus1
Mar 13 18:23:05 freenas kernel: uhub1: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1
Mar 13 18:23:05 freenas kernel: uhub0: 8 ports with 8 removable, self powered
Mar 13 18:23:05 freenas kernel: uhub1: 8 ports with 8 removable, self powered
Mar 13 18:23:05 freenas kernel: cd0 at ata1 bus 0 scbus1 target 0 lun 0
Mar 13 18:23:05 freenas kernel: cd0: <VBOX CD-ROM 1.0> Removable CD-ROM SCSI-0 device
Mar 13 18:23:05 freenas kernel: cd0: 33.300MB/s transfers (UDMA2, ATAPI 12bytes, PIO 65534bytes)
Mar 13 18:23:05 freenas kernel: cd0: Attempt to query device size failed: NOT READY, Medium not present
Mar 13 18:23:05 freenas kernel: ada0 at ata0 bus 0 scbus0 target 0 lun 0
Mar 13 18:23:05 freenas kernel: ada0: <VBOX HARDDISK 1.0> ATA-6 device
Mar 13 18:23:05 freenas kernel: ada0: 33.300MB/s transfers (UDMA2, PIO 65536bytes)
Mar 13 18:23:05 freenas kernel: ada0: 2048MB (4194304 512 byte sectors: 16H 63S/T 4161C)
Mar 13 18:23:05 freenas kernel: ada1 at ata0 bus 0 scbus0 target 1 lun 0
Mar 13 18:23:05 freenas kernel: ada1: <VBOX HARDDISK 1.0> ATA-6 device
Mar 13 18:23:05 freenas kernel: ada1: 33.300MB/s transfers (UDMA2, PIO 65536bytes)
Mar 13 18:23:05 freenas kernel: ada1: 1024000MB (2097152000 512 byte sectors: 16H 63S/T 16383C)
Mar 13 18:23:05 freenas kernel: Trying to mount root from ufs:/dev/ufs/FreeNASs1a
Mar 13 18:23:05 freenas root: /etc/rc: WARNING: failed precmd routine for vmware_guestd
Mar 13 18:23:06 freenas kernel: ZFS NOTICE: Prefetch is disabled by default on i386 -- to enable,
Mar 13 18:23:06 freenas kernel: add "vfs.zfs.prefetch_disable=0" to /boot/loader.conf.
Mar 13 18:23:06 freenas kernel: ZFS WARNING: Recommended minimum kmem_size is 512MB; expect unstable behavior.
Mar 13 18:23:06 freenas kernel: Consider tuning vm.kmem_size and vm.kmem_size_max
Mar 13 18:23:06 freenas kernel: in /boot/loader.conf.
Mar 13 18:23:06 freenas kernel: ZFS filesystem version 4
Mar 13 18:23:06 freenas kernel: ZFS storage pool version 15
Mar 13 18:23:07 freenas ntpd[1432]: ntpd 4.2.4p5-a (1)
Mar 13 18:23:09 freenas freenas[1682]: Popen()ing: mount|grep "/dev/ufs/Daten"
Mar 13 17:23:16 freenas ntpd[1433]: time reset -3598.421035 s
Mar 13 17:25:01 freenas freenas[2214]: Popen()ing: mount|grep "/dev/ufs/Daten"
Mar 13 17:26:39 freenas freenas[1681]: Executing: /usr/sbin/service dbus forcestop
Mar 13 17:26:39 freenas freenas: dbus not running? (check /var/run/dbus/dbus.pid).
Mar 13 17:26:39 freenas freenas[1681]: Executing: /usr/sbin/service dbus restart
Mar 13 17:26:39 freenas freenas: Will not 'restart' dbus because dbus_enable is NO.
Mar 13 17:26:39 freenas freenas[1681]: Executing: /usr/sbin/service avahi-daemon forcestop
Mar 13 17:26:39 freenas freenas: Stopping avahi-daemon.
Mar 13 17:26:39 freenas freenas: Failed to kill daemon: No such file or directory
Mar 13 17:26:39 freenas freenas[1681]: Executing: /usr/sbin/service avahi-daemon restart
Mar 13 17:26:39 freenas freenas: Will not 'restart' avahi_daemon because avahi_daemon_enable is NO.
Mar 13 17:26:39 freenas freenas[1681]: Executing: /usr/bin/killall nmbd
Mar 13 17:26:39 freenas freenas: No matching processes were found
Mar 13 17:26:39 freenas freenas[1681]: Executing: /usr/bin/killall smbd
Mar 13 17:26:39 freenas freenas[1681]: Executing: /usr/sbin/service samba quietstart
Mar 13 17:26:39 freenas freenas: Removing stale Samba tdb files: done
Mar 13 17:26:40 freenas freenas[1681]: Executing: /bin/pgrep -F /var/run/samba/smbd.pid smbd
Mar 13 17:26:46 freenas freenas[1681]: Executing: /usr/sbin/service dbus forcestop
Mar 13 17:26:46 freenas freenas: dbus not running? (check /var/run/dbus/dbus.pid).
Mar 13 17:26:46 freenas freenas[1681]: Executing: /usr/sbin/service dbus restart
Mar 13 17:26:46 freenas freenas: Will not 'restart' dbus because dbus_enable is NO.
Mar 13 17:26:46 freenas freenas[1681]: Executing: /usr/sbin/service avahi-daemon forcestop
Mar 13 17:26:46 freenas freenas: Stopping avahi-daemon.
Mar 13 17:26:46 freenas freenas: Failed to kill daemon: No such file or directory
Mar 13 17:26:46 freenas freenas[1681]: Executing: /usr/sbin/service avahi-daemon restart
Mar 13 17:26:46 freenas freenas: Will not 'restart' avahi_daemon because avahi_daemon_enable is NO.
Mar 13 17:26:46 freenas freenas[1681]: Executing: /usr/bin/killall nmbd
Mar 13 17:26:46 freenas freenas: No matching processes were found
Mar 13 17:26:46 freenas freenas[1681]: Executing: /usr/bin/killall smbd
Mar 13 17:26:46 freenas freenas[1681]: Executing: /usr/sbin/service samba quietstart
Mar 13 17:26:46 freenas freenas: Removing stale Samba tdb files: done
Mar 13 17:26:47 freenas freenas[1681]: Executing: /bin/pgrep -F /var/run/samba/smbd.pid smbd
Mar 13 17:26:59 freenas freenas[1681]: Executing: /usr/sbin/service dbus forcestop
Mar 13 17:26:59 freenas freenas: dbus not running? (check /var/run/dbus/dbus.pid).
Mar 13 17:26:59 freenas freenas[1681]: Executing: /usr/sbin/service dbus restart
Mar 13 17:26:59 freenas freenas: Will not 'restart' dbus because dbus_enable is NO.
Mar 13 17:26:59 freenas freenas[1681]: Executing: /usr/sbin/service avahi-daemon forcestop
Mar 13 17:26:59 freenas freenas: Stopping avahi-daemon.
Mar 13 17:26:59 freenas freenas: Failed to kill daemon: No such file or directory
Mar 13 17:26:59 freenas freenas[1681]: Executing: /usr/sbin/service avahi-daemon restart
Mar 13 17:26:59 freenas freenas: Will not 'restart' avahi_daemon because avahi_daemon_enable is NO.
Mar 13 17:26:59 freenas freenas[1681]: Executing: /usr/bin/killall nmbd
Mar 13 17:26:59 freenas freenas: No matching processes were found
Mar 13 17:26:59 freenas freenas[1681]: Executing: /usr/bin/killall smbd
Mar 13 17:26:59 freenas freenas[1681]: Executing: /usr/sbin/service samba quietstart
Mar 13 17:26:59 freenas freenas: Removing stale Samba tdb files: done
Mar 13 17:26:59 freenas freenas[1681]: Executing: /bin/pgrep -F /var/run/samba/smbd.pid smbd
Kannst du etwas damit anfangen?
