maxdevaine
- May 16, 2017
I have created VM in FreeNAS 11 web interface, all works ok. But I need periodically stop VM, revert snapshot and start VM.
I can't found solution for start VM from command line.
bhyvectl not see my VM
iohyve not see my VM
vm command give error : /usr/local/sbin/vm: ERROR: $vm_enable is not enabled in /etc/rc.conf!
So, is there any solution? I have only one VM with autostart option, so if is not possible to run VM directly, it is possible to run autostart procedure for all VMs without restart FreeNAS?
Thank for any solution
Max Devaine
Max Devaine
