- Nov 12, 2015
FreeNAS Community,
Pleased to announce that FreeNAS 11.3-RELEASE is now available! This marks our first major release of 2020 and brings with it a slew of new features and functionality, including but not limited to:
Full Release Notes:
https://www.ixsystems.com/blog/library/freenas-11-3-release/
Download:
https://www.freenas.org/download/
Issue Tracker:
https://jira.ixsystems.com
- Re-implemented Replication Engine, allows up to 10Gb replication speeds (a 10x improvement), resume support on failed transfers, as well as ability to replicate locally.
- ACL Manager – Allows setup and management of SMB ACL’s directly via the FreeNAS web interface.
- SMB Shadow Copies are now enabled by default for new shares – Note: Snapshots will only show up in Windows “Previous Versions Tab” if the snapshot USED size shows changes to the file.
- A repository of Community plugins has been created, users can now create and distribute 3rd party plugins which are not officially iXsystems supported.
- Updated translations for Czech, French, Japanese, Russian, and Simplified Chinese. Additionally, the process to add additional translations has been greatly improved.
- iSCSI Wizard – Streamlines the process of creating new iSCSI targets down to a few clicks.
- Alert System Overhaul – More granular alerts, as well as controls to set alert thresholds.
- Dashboard Updates – The initial dashboard now shows a live view of system status, including network traffic, CPU / memory utilization and more.
- NAT Support for Plugins – Eliminates the need for each plugin to have a dedicated IP address on your network.
- Full featured 2.0 API – Includes both REST and Websocket connections, allowing FreeNAS to be fully scripted and driven via the same API used by the web-interface.
- Large Pool Creation Assistance – When creating ZFS pools with large number of disks, the UI provides an automated way to repeat a VDEV layout across all remaining disks.
- ZFS Performance optimizations across the board for many different workloads.
Full Release Notes:
Download:
Issue Tracker:
