FreeNAS 11.2-RELEASE has arrived!
Mannekino
VNET networking for my jails doesn't work anymore after the update. Reverting back to U1 now.
Ixian
And same here. Wow. What a whopper of a bug that got through :)
Has a bug report been filed?
zvans18
VNET works fine for me, but rrdtool is crashy as hell (segfault)
ThreeDee
no connectivity to plex, rolling back!
Ixian
Also saw issues (segfault exit 11) with rrdtool and U2 before I rolled back to U1.
rknaub
local variable 'bridge_cmd' referenced before assignment
None of my jails work , rolling back now.
hervon
vnet fails here too ...
Ixian
Everyone with vnet issues, what is your boot device? i.e. USB, SATA, etc.
ThreeDee
Was a thumb drive .. but took advantage of being down and threw in a 128GB SSD on a SATA to USB cable and restored config file I saved before I tried the U2 update. I'm back up and running just peachily again.
Ixian
To be clear, are you back up and running on U1, or U2? Wondering if slower boot devices is the culprit since the error appears to be related to the bridge service not starting in time for the jails.
tonarm
Same Vnet error on mine, after Rollback to U1 everything working again. Boot is an ssd.
Mannekino
@Ixian my boot devices are two Sandisk USB drives in a mirrored setup. One is plugged in the motherboard the other one in the back I/O plate. I have a Supermicro X9SCM-F motherboard. I activated the boot environment for U1 and rebooted. After that the jail networks were working again.
To other people: did you also uploaded the config you saved during the upgrade process after reverting back to U1 or is that not necessary?
enemy85
well, then i guess i'll wait before upgrading... ;)
Chris Moore
I understand the need to roll back to a stable state, but if you are having problems after an update, please file a bug report first.
Then roll back and live happy knowing that you helped to fix what was not working.
