The running rancher-server/agent and their related containers can be viewed using
docker ps
. (Remember rancher server/agent etc can run on other linux distros as well as rancheros. ) . eg:
root@rancher:~# docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAM
ES
3176a6077906 rancher/scheduler:v0.8.2 "/.r/r /rancher-en..." 3 days ago Up About a minute r-s
cheduler-scheduler-1-7030b29a
8d23629722d9 rancher/storage-nfs:v0.8.5 "start.sh storage ..." 11 days ago Up About a minute r-n
fs-nfs-driver-1-00ec47cc
44213a15c28d rancher/healthcheck:v0.3.3 "/.r/r /rancher-en..." 2 weeks ago Up About a minute r-h
ealthcheck-healthcheck-1-14795046
74d04ac0295c rancher/net:v0.13.5 "/rancher-entrypoi..." 2 weeks ago Up About a minute r-i
psec-cni-driver-1-b8e46d60
6cd01ac9ac24 rancher/dns:v0.15.3 "/rancher-entrypoi..." 2 weeks ago Up About a minute r-n
etwork-services-metadata-dns-1-aede8559
b5381f05f099 rancher/network-manager:v0.7.18 "/rancher-entrypoi..." 2 weeks ago Up About a minute r-n
etwork-services-network-manager-1-7bcc510f
7fd18fc19e39 rancher/net:holder "/.r/r /rancher-en..." 2 weeks ago Up About a minute r-i
psec-ipsec-1-987d5a01
3f60422fbf82 rancher/metadata:v0.9.5 "/rancher-entrypoi..." 2 weeks ago Up About a minute r-n
etwork-services-metadata-1-3a5fc1ad
1379cbb07009 rancher/agent:v1.2.7 "/run.sh run" 2 weeks ago Up 3 minutes ran
cher-agent
defcfa170620 rancher/server "/usr/bin/entry /u..." 2 weeks ago Up 3 minutes 3306/tcp, 0.0.0.0:8080->8080/tcp won
derful_varahamihira
I believe all the rancher config data is held internally, some of it in SQL tables. See here for further details:
http://rancher.com/docs/rancher/v1.6/en/faqs/server/
You've not said if the host you've registered with the rancher-server, and whose details are being lost, is the same host that's actually running the rancher-server. Assuming this is true and you only have a single DockerVM running, then I have not encountered your problem in my limited use of rancher while testing in FreeNAS 11.1, nor using the same combination running in virtualbox on a linux desktop.
Other than looking at the references I gave you to troubleshoot your problem, the rancher system logs might provide some clues. I'm afraid I cannot advise further.
