Nasb Klamb
- Apr 1, 2017
I'm trying to understand how to best use Docker VMs on 11.1. I've successfully created the rancher UI and another VM host node. But I have a few things (so far) that I can't find info about:
1. Upgrading the Rancher OS in a VM. The installed version is 1.1.0, but 1.1.1 is available. The documented "sudo ros os upgrade" process works and the system reboots. But it is still at 1.1.0. Is there a way to do this?
2. Mounting/sharing storage with containers. From what I can read, using nfs shares is the best way to go. I have shares defined in my freenas. But when I try to mount one of them in my rancher vm, it hangs. E.g. "mount -t nfs alpha:/mnt/vol1/media:/mnt/host_media" hangs.
3. Related to (1), how does booting work with the docker vm? It is created to use grub. And the logs suggest that /boot is where I should find the grub stuff, but the booted system has no /boot directory.
Thanks!
Thanks!
