kdragon75
- Aug 7, 2016
Hello, I'm trying to get ctl and CARP working to implement a shared storages HA configuration. I have the ctl HA setup* for the failover of the CTL front end ports. The part I'm hung up on is the CARP setup. It seems like it should be quite simple but both hosts ctlr-a and ctlr-b are stuck in
"Backup". I could use a second set of eyes to look over my config. Note, I am not using preempt as I want to implement hold down timers and flapper limits to prevent an endless loop of flip flopping.
ctlr-a:
ctlr-b:
disabling either hosts network via cable pull or
Any insights would be appreciated!
ctlr-a:
root@ctlr-a:~ # ifconfig vmx0 vmx0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=60039b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,TSO4,TSO6,RXCSUM_IPV6,TXCSUM_IPV6> ether 00:50:56:88:89:ac hwaddr 00:50:56:88:89:ac inet 192.168.1.243 netmask 0xffffff00 broadcast 192.168.1.255 inet 192.168.1.245 netmask 0xffffffff broadcast 192.168.1.245 vhid 1 nd6 options=29<PERFORMNUD,IFDISABLED,AUTO_LINKLOCAL> media: Ethernet autoselect status: active carp: BACKUP vhid 1 advbase 1 advskew 1 root@ctlr-a:~ # cat /etc/rc.conf hostname="ctlr-a" defaultrouter="192.168.1.1" ifconfig_vmx0="inet 192.168.1.243/24" ifconfig_vmx0_alias0="inet vhid 1 pass pa$$w0rd advskew 1 alias 192.168.1.245/24" sshd_enable="YES" # Set dumpdev to "AUTO" to enable crash dumps, "NO" to disable dumpdev="NO" zfs_enable="YES" ctld_enable="yes"
ctlr-b:
root@ctlr-b:~ # ifconfig vmx0 vmx0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=60039b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,TSO4,TSO6,RXCSUM_IPV6,TXCSUM_IPV6> ether 00:50:56:88:63:2d hwaddr 00:50:56:88:63:2d inet 192.168.1.244 netmask 0xffffff00 broadcast 192.168.1.255 inet 192.168.1.245 netmask 0xffffffff broadcast 192.168.1.245 vhid 1 nd6 options=29<PERFORMNUD,IFDISABLED,AUTO_LINKLOCAL> media: Ethernet autoselect status: active carp: BACKUP vhid 1 advbase 1 advskew 2 root@ctlr-b:~ # cat /etc/rc.conf hostname="ctlr-b" defaultrouter="192.168.1.1" ifconfig_vmx0="inet 192.168.1.244/24" ifconfig_vmx0_alias0="inet vhid 1 pass pa$$w0rd advskew 2 alias 192.168.1.245/24" sshd_enable="YES" # Set dumpdev to "AUTO" to enable crash dumps, "NO" to disable dumpdev="NO" zfs_enable="YES" ctld_enable="yes"
ifconfig vmx0 down
seems to have no effect and running tcpdump -T carp | grep carp
shows nothing. Both hosts can ping each other and the gateway. As this is running in ESXi 6.7 I have also set the following policies on the port group.Code:
Security Promiscuous mode Accept MAC address changes Accept Forged transmits Accept
