zbuc
- Dec 9, 2014
I changed my subnet and now I'm having trouble getting my jails up and running again.
My old subnet was 192.168.1.0/24, now I'm on 192.168.88.0/24.
FreeNAS received an IP via DHCP fine and I can reach it (192.168.88.61) and manage it through the web interface.
However, if I select either DHCP or try setting a static IP in the web UI for my jails, they still maintain an address on the old subnet -- even if the front-end says they're on the new subnet (this happens when I use a static address).
I've tried restarting the box and that didn't help.
Any ideas? I can't run dhclient or ifconfig within a jail because they don't have permission to the network device...
edit: oh, yea, setting that one to 192.168.88.255 was dumb, but it makes no difference for the problem i'm having
Running FreeNAS-9.3-STABLE-201512121950
~# ifconfig
em0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=98<VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM>
ether 00:0c:29:48:5a:64
inet 192.168.88.61 netmask 0xffffff00 broadcast 192.168.88.255
inet 192.168.1.108 netmask 0xffffff00 broadcast 192.168.1.255
inet 192.168.1.104 netmask 0xffffff00 broadcast 192.168.1.255
inet 192.168.1.106 netmask 0xffffff00 broadcast 192.168.1.255
inet 192.168.1.105 netmask 0xffffff00 broadcast 192.168.1.255
inet 192.168.1.102 netmask 0xffffff00 broadcast 192.168.1.255
inet 192.168.1.103 netmask 0xffffff00 broadcast 192.168.1.255
inet 192.168.1.100 netmask 0xffffff00 broadcast 192.168.1.255
inet 192.168.1.101 netmask 0xffffff00 broadcast 192.168.1.255
inet 192.168.1.109 netmask 0xffffff00 broadcast 192.168.1.255
inet 192.168.1.107 netmask 0xffffff00 broadcast 192.168.1.255
media: Ethernet autoselect (1000baseT <full-duplex>)
status: active
ipfw0: flags=8801<UP,SIMPLEX,MULTICAST> metric 0 mtu 65536
options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x3
ether 02:83:f0:a3:31:00
nd6 options=1<PERFORMNUD>
member: epair0a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 5 priority 128 path cost 2000
member: em0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 1 priority 128 path cost 20000
epair0a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
ether 02:1c:ba:00:05:0a
status: active
~# jls
JID IP Address Hostname Path
1 192.168.1.108 beets /mnt/Main/jails/beets
2 192.168.1.104 couchpotato.local /mnt/Main/jails/couchpotato_1
3 192.168.1.106 dynamicdns /mnt/Main/jails/dynamicdns
4 192.168.1.105 headphones_1 /mnt/Main/jails/headphones_1
5 192.168.1.102 htpc.local /mnt/Main/jails/htpc-manager_1
6 - musicbrainz /mnt/Main/jails/musicbrainz
7 192.168.1.103 plex.local /mnt/Main/jails/plexmediaserver_1
8 192.168.1.100 sabnzbd_1 /mnt/Main/jails/sabnzbd_1
9 192.168.1.101 sickbeard_1 /mnt/Main/jails/sickbeard_1
10 192.168.1.109 subsonic /mnt/Main/jails/subsonic
11 192.168.1.107 transmission_1 /mnt/Main/jails/transmission_1
