Jails lost connectivity
tranqme
I stupidly decided to rename the vSwitch in ESXi that my VMs were using and this has messed up the networking for my FreeNAS host/jails. I managed to sort out the host, although I'm still struggling with the jails.
At this point, the I can ping the jails from the host and vice versa. However, they are not contactable from any other device on my network, nor can they contact the outside world.
I also noticed some log messages appearing occasionally on the host, which concerns me as I recall seeing 'epair0/epair1' being used instead prior to the vSwitch change:
epair2a: Ethernet address: mac
epair2b: Ethernet address: mac
I've spent way too much time researching and trying different fixes to get these jails back up and running, and I would really appreciate some assistance as I don't wish to re-create them from scratch.
Host ifconfig:
vmx0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=200099<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,RXCSUM_IPV6>
        ether 00:0c:29:4a:8f:df
        hwaddr 00:0c:29:4a:8f:df
        inet 192.168.1.5 netmask 0xffffff00 broadcast 192.168.1.255
        media: Ethernet autoselect
        status: active
        options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
        inet6 ::1 prefixlen 128
        inet6 fe80::1%lo0 prefixlen 64 scopeid 0x2
        groups: lo
        ether 02:1e:f2:62:c6:00
        nd6 options=1<PERFORMNUD>
        groups: bridge
        member: vnet0:3 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 6 priority 128 path cost 2000
        member: vnet0:2 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 5 priority 128 path cost 2000
        member: vnet0:1 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 4 priority 128 path cost 2000
        member: vmx0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 1 priority 128 path cost 2000
vnet0:1: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        description: associated with jail: transmission as nic: epair0b
        options=8<VLAN_MTU>
        ether 00:0c:29:03:aa:46
        hwaddr 02:c7:d0:00:04:0a
        status: active
        groups: epair
vnet0:2: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        description: associated with jail: couchpotato as nic: epair0b
        options=8<VLAN_MTU>
        ether 00:0c:29:1c:24:41
        hwaddr 02:c7:d0:00:05:0a
        status: active
        groups: epair
vnet0:3: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        description: associated with jail: plex as nic: epair0b
        options=8<VLAN_MTU>
        ether 00:0c:29:14:fa:09
        hwaddr 02:c7:d0:00:06:0a
        status: active
        groups: epair
Sample jail ifconfig:
        inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
        groups: lo
epair0b: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=8<VLAN_MTU>
        ether 00:0c:29:14:fa:0a
        hwaddr 02:c7:d0:00:07:0b
        inet 192.168.1.6 netmask 0xffffff00 broadcast 192.168.1.255
        status: active
        groups: epair
