I'm new to FreeNAS and have my ZFS pool set up and shared through SMB which has been working great so far, but I'm having issues getting plugins working. I'm focusing on Plex first, but I've tried other plugins and empty jails with the same issues. FreeNAS itself has no problems connecting to the internet or pinging Google.
By default, they want to install with VNET/BPF enabled, but it doesn't seem that the jail can access the internet because I get the following error whether I use DHCP or manually assigned IPv4 info:
If I disable VNET/BPF and choose my normal interface (igb0), I'm able to install and run Plex, but it can't download any metadata. I've read that it needs VNET to be able to do so, but I can't connect to the internet or ping anything once I turn VNET on, switch to the vnet0 interface, configure the default router, and allow raw sockets.
FreeNAS ifconfig:
Plex jail ifconfig with VNET on:
Plex jail ifconfig with VNET off:
[EFAULT] Exception: CallError:[EFAULT] pkg error: - pkg-static: Repository iocage-plugins load error: access repo file(/var/db/pkg/repo-iocage-plugins.sqlite) failed: No such file or directory pkg-static: http://pkg.cdn.trueos.org/iocage/11.2-RELEASE/meta.txz: Service Unavailable pkg-static: http://pkg.cdn.trueos.org/iocage/11.2-RELEASE/packagesite.txz: Service Unavailable Please check your network occured, destroyed plex.
FreeNAS ifconfig:
igb0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=2400b9<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,VLAN_HWTSO,RXCSUM_IPV6> ether 00:25:90:e3:8c:24 hwaddr 00:25:90:e3:8c:24 inet 192.168.1.20 netmask 0xffffff00 broadcast 192.168.1.255 nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet autoselect (1000baseT <full-duplex>) status: active igb1: flags=8c02<BROADCAST,OACTIVE,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=6403bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,VLAN_HWTSO,RXCSUM_IPV6,TXCSUM_IPV6> ether 00:25:90:e3:8c:25 hwaddr 00:25:90:e3:8c:25 nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet autoselect status: no carrier lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384 options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6> inet6 ::1 prefixlen 128 inet6 fe80::1%lo0 prefixlen 64 scopeid 0x3 inet 127.0.0.1 netmask 0xff000000 nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL> groups: lo bridge0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 ether 02:fc:8f:21:c5:00 nd6 options=1<PERFORMNUD> id 00:00:00:00:00:00 priority 32768 hellotime 2 fwddelay 15 maxage 20 holdcnt 6 proto rstp maxaddr 2000 timeout 1200 root id 00:00:00:00:00:00 priority 32768 ifcost 0 port 0 member: vnet0:15 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 5 priority 128 path cost 2000 member: igb0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 1 priority 128 path cost 20000 vnet0:15: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 description: associated with jail: plex as nic: epair0b options=8<VLAN_MTU> ether 00:25:90:14:fa:09 hwaddr 02:fe:d0:00:05:0a nd6 options=1<PERFORMNUD> media: Ethernet 10Gbase-T (10Gbase-T <full-duplex>) status: active groups: epair
lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384 options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6> inet6 ::1 prefixlen 128 inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1 inet 127.0.0.1 netmask 0xff000000 nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL> groups: lo epair0b: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=8<VLAN_MTU> ether 00:25:90:14:fa:0a hwaddr 02:fe:d0:00:06:0b inet 192.168.1.21 netmask 0xffffff00 broadcast 192.168.1.255 nd6 options=1<PERFORMNUD> media: Ethernet 10Gbase-T (10Gbase-T <full-duplex>) status: active groups: epair
igb0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=6403bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,VLAN_HWTSO,RXCSUM_IPV6,TXCSUM_IPV6> ether 00:25:90:e3:8c:24 hwaddr 00:25:90:e3:8c:24 inet 192.168.1.21 netmask 0xffffff00 broadcast 192.168.1.255 media: Ethernet autoselect (1000baseT <full-duplex>) status: active igb1: flags=8c02<BROADCAST,OACTIVE,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=6403bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,VLAN_HWTSO,RXCSUM_IPV6,TXCSUM_IPV6> ether 00:25:90:e3:8c:25 hwaddr 00:25:90:e3:8c:25 media: Ethernet autoselect status: no carrier lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384 options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6> groups: lo bridge0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 ether 02:fc:8f:21:c5:00 id 00:00:00:00:00:00 priority 32768 hellotime 2 fwddelay 15 maxage 20 holdcnt 6 proto rstp maxaddr 2000 timeout 1200 root id 00:00:00:00:00:00 priority 32768 ifcost 0 port 0 member: igb0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 1 priority 128 path cost 20000
