I'm new to FreeNAS and have my ZFS pool set up and shared through SMB which has been working great so far, but I'm having issues getting plugins working. I'm focusing on Plex first, but I've tried other plugins and empty jails with the same issues. FreeNAS itself has no problems connecting to the internet or pinging Google.
By default, they want to install with VNET/BPF enabled, but it doesn't seem that the jail can access the internet because I get the following error whether I use DHCP or manually assigned IPv4 info:
If I disable VNET/BPF and choose my normal interface (igb0), I'm able to install and run Plex, but it can't download any metadata. I've read that it needs VNET to be able to do so, but I can't connect to the internet or ping anything once I turn VNET on, switch to the vnet0 interface, configure the default router, and allow raw sockets.
FreeNAS ifconfig:
Plex jail ifconfig with VNET on:
Plex jail ifconfig with VNET off:
[EFAULT] Exception: CallError:[EFAULT] pkg error: - pkg-static: Repository iocage-plugins load error: access repo file(/var/db/pkg/repo-iocage-plugins.sqlite) failed: No such file or directory pkg-static: http://pkg.cdn.trueos.org/iocage/11.2-RELEASE/meta.txz: Service Unavailable pkg-static: http://pkg.cdn.trueos.org/iocage/11.2-RELEASE/packagesite.txz: Service Unavailable Please check your network occured, destroyed plex.
FreeNAS ifconfig:
igb0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=2400b9<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,VLAN_HWTSO,RXCSUM_IPV6>
ether 00:25:90:e3:8c:24
hwaddr 00:25:90:e3:8c:24
inet 192.168.1.20 netmask 0xffffff00 broadcast 192.168.1.255
media: Ethernet autoselect (1000baseT <full-duplex>)
status: active
igb1: flags=8c02<BROADCAST,OACTIVE,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=6403bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,VLAN_HWTSO,RXCSUM_IPV6,TXCSUM_IPV6>
ether 00:25:90:e3:8c:25
hwaddr 00:25:90:e3:8c:25
status: no carrier
options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x3
groups: lo
ether 02:fc:8f:21:c5:00
nd6 options=1<PERFORMNUD>
member: vnet0:15 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 5 priority 128 path cost 2000
member: igb0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 1 priority 128 path cost 20000
vnet0:15: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: plex as nic: epair0b
options=8<VLAN_MTU>
ether 00:25:90:14:fa:09
hwaddr 02:fe:d0:00:05:0a
status: active
groups: epairPlex jail ifconfig with VNET on:
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
groups: lo
epair0b: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
ether 00:25:90:14:fa:0a
hwaddr 02:fe:d0:00:06:0b
inet 192.168.1.21 netmask 0xffffff00 broadcast 192.168.1.255
status: active
groups: epairPlex jail ifconfig with VNET off:
status: active
status: no carrier
groups: lo
