Hi guys,
i did a fresh install of Freenas 11.2 BETA3 but cant get the iocage jail vnet0 networking to work, see the following information below. freenas has networking working no problem ie. default gateway, 192.168.1.1, dns 8.8.8.8 and 8.8.4.4 can ping also www.google.com. i also tried a test jail using the FN NIC vmx0 instead of vnet0 and its working properly can get networking.
i prefer to use vnet0 if possible to get the full stack for unifi controller and plex.
please help i'm stuck!!!
let me know if you need more information
Thank you
what i done:
System > Tunables
Variable: cloned_interfaces, Value: bridge0, Type: rc.conf
Variable: ifconfig_bridge0, Value: addm vnet0 up, Type: rc.conf
rc.conf added rename ifconfig_epair0_name="epair0b"
Jail ifconfig
Freenas
Thank you
what i done:
iocage create -r 11.2-RELEASE -n Unifi ip4_addr="vnet0|192.168.1.5/24" defaultrouter=192.168.1.1 vnet=on boot=on allow_raw_sockets=1
System > Tunables
host_hostname="Unifi" cron_flags="$cron_flags -J 15" # Disable Sendmail by default sendmail_enable="NONE" sendmail_submit_enable="NO" sendmail_outbound_enable="NO" sendmail_msp_queue_enable="NO" # Run secure syslog syslogd_flags="-c -ss" # Enable IPv6 ipv6_activate_all_interfaces="YES" ifconfig_epair0_name="epair0b"
Jail ifconfig
root@Unifi:~ # ifconfig lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384 options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6> inet6 ::1 prefixlen 128 inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1 inet 127.0.0.1 netmask 0xff000000 nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL> groups: lo epair0b: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=8<VLAN_MTU> ether 02:ff:60:5a:44:c5 hwaddr 02:70:d0:00:06:0b inet 192.168.1.5 netmask 0xffffff00 broadcast 192.168.1.255 nd6 options=1<PERFORMNUD> media: Ethernet 10Gbase-T (10Gbase-T <full-duplex>) status: active groups: epair
Freenas
[root@freenas ~]# ifconfig vmx0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=200099<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,RXCSUM_IPV6> ether 00:0c:29:ab:00:cc hwaddr 00:0c:29:ab:00:cc inet 192.168.1.6 netmask 0xffffff00 broadcast 192.168.1.255 nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet autoselect status: active vmx1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=60039b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,TSO4,TSO6,RXCSUM_IPV6,TXCSUM_IPV6> ether 00:0c:29:ab:00:d6 hwaddr 00:0c:29:ab:00:d6 inet 10.55.1.2 netmask 0xffff0000 broadcast 10.55.255.255 nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet autoselect status: active lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384 options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6> inet6 ::1 prefixlen 128 inet6 fe80::1%lo0 prefixlen 64 scopeid 0x3 inet 127.0.0.1 netmask 0xff000000 nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL> groups: lo bridge0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 ether 02:37:cb:83:75:00 nd6 options=1<PERFORMNUD> groups: bridge id 00:00:00:00:00:00 priority 32768 hellotime 2 fwddelay 15 maxage 20 holdcnt 6 proto rstp maxaddr 2000 timeout 1200 root id 00:00:00:00:00:00 priority 32768 ifcost 0 port 0 member: vnet0:9 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 5 priority 128 path cost 2000 member: vmx0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 1 priority 128 path cost 2000 vnet0:9: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 description: associated with jail: Unifi options=8<VLAN_MTU> ether 02:ff:60:5a:44:c4 hwaddr 02:70:d0:00:05:0a nd6 options=1<PERFORMNUD> media: Ethernet 10Gbase-T (10Gbase-T <full-duplex>) status: active groups: epair
[root@freenas ~]# iocage get all Unifi CONFIG_VERSION:11 allow_chflags:0 allow_mount:0 allow_mount_devfs:0 allow_mount_nullfs:0 allow_mount_procfs:0 allow_mount_tmpfs:0 allow_mount_zfs:0 allow_quotas:0 allow_raw_sockets:1 allow_set_hostname:1 allow_socket_af:0 allow_sysvipc:0 available:readonly basejail:no boot:on bpf:yes children_max:0 cloned_release:11.2-RELEASE comment:none compression:lz4 compressratio:readonly coredumpsize:off count:1 cpuset:off cputime:off datasize:off dedup:off defaultrouter:192.168.1.1 defaultrouter6:none depends:none devfs_ruleset:4 dhcp:off enforce_statfs:2 exec_clean:1 exec_fib:0 exec_jail_user:root exec_poststart:/usr/bin/true exec_poststop:/usr/bin/true exec_prestart:/usr/bin/true exec_prestop:/usr/bin/true exec_start:/bin/sh /etc/rc exec_stop:/bin/sh /etc/rc.shutdown exec_system_jail_user:0 exec_system_user:root exec_timeout:60 host_domainname:none host_hostname:Unifi host_hostuuid:Unifi host_time:yes hostid:b7e71a60-b7da-11e8-8865-000c29ab00cc hostid_strict_check:off interfaces:vnet0:bridge0 ip4:new ip4_addr:vnet0|192.168.1.5/24 ip4_saddrsel:1 ip6:new ip6_addr:none ip6_saddrsel:1 jail_zfs:off jail_zfs_dataset:iocage/jails/Unifi/data jail_zfs_mountpoint:none last_started:2018-09-17 00:20:36 login_flags:-f root mac_prefix:02ff60 maxproc:off memorylocked:off memoryuse:off mount_devfs:1 mount_fdescfs:1 mount_linprocfs:0 mount_procfs:0 mountpoint:readonly msgqqueued:off msgqsize:off nmsgq:off notes:none nsemop:off nshm:off nthr:off openfiles:off origin:readonly owner:root pcpu:off priority:99 pseudoterminals:off quota:none release:11.2-RELEASE-p3 reservation:none resolver:/etc/resolv.conf rlimits:off securelevel:2 shmsize:off stacksize:off state:down stop_timeout:30 swapuse:off sync_state:none sync_target:none sync_tgt_zpool:none sysvmsg:new sysvsem:new sysvshm:new template:no type:jail used:readonly vmemoryuse:off vnet:on vnet0_mac:02ff605a44c4,02ff605a44c5 vnet1_mac:none vnet2_mac:none vnet3_mac:none vnet_interfaces:none wallclock:off
