Resource icon
FN11.3 iocage jails - Plex, Tautulli, Sonarr, Radarr, Lidarr, Jackett, Transmission, Organizr
DarkeBlayze
If I understand your information, you have '/mnt/JailHD/apps/transmission' mounted to /config in transmission jail. which would put your file at '/config/config/ipfw_rules' inside the jail.
try moving ipfw_rules down one folder.
I think that will put the file in the correct place for the chmod command to succeed.
You were completely correct! that's now working absolutely fine. Thanks!
now I've just got to figure out why openvpn is failing to start... woop!
DarkeBlayze
for iocage exec transmission sysrc "openvpn_configfile=/config/openvpn.conf"
does openvpn.conf need to be in the same place as where i moved ipfw_rules to?
DarkeBlayze
Honestly, im coming accross a whole host of issues with transmission and openvpn... I don't know where to go from here so i guess i'll try again tomorrow...
i've installed it 5 times following the guide. openvpn NEVER runs.
transmission started working, but once i edit settings.json to allow my ip, transmission was no longer able to read it....
Couldn't read "/config/transmission-home/settings.json": permission denied.
It was denied before i edited it. I'm lost.
NasKar
they should to be in the same place.
make sure the jail has a tun interface with ifconfig
then make sure that the openvpn file has tun0 in the file, if that is what showed up in the ifconfig command.
check that ipfw.rules has the correct tun number as well.
DarkeBlayze
my openvpn.conf is
client
dev tun0
proto udp
remote 95.xxx.xxx.239 80
remote " " 443
remote " " 4569
remote " " 1194
remote " " 5060
remote-random
resolve-retry infinite
nobind
cipher AES-256-CBC
auth SHA512
comp-lzo no
verb 3
tun-mtu 1500
tun-mtu-extra 32
mssfix 1450
persist-key
persist-tun
reneg-sec 0
remote-cert-tls server
auth-user-pass /mnt/JAILHD/............................./
auth-nocache
pull
fast-io
script-security 2
up /etc/openvpn/update-resolv-conf
down /etc/openvpn/update-resolve-conf
and my ipfw_rules is
# Allow internal traffic
add 03000 allow IP from 192.xxx.x.x/32 to 192.xxx.x.x/32 keep-state
# Allow access to Entrance IP for VPN
add 04000 allow IP from 192.xxx.x.x/32 to 95.xxx.x.x/32 keep-state
# Allow any traffic over the vpn interface
add 05000 allow IP from any to any via tun0
# Deny any other trafic
add 65534 deny IP from any to any.
does this all look correct? as it's still not starting.
NasKar
What is the ifconfig
DarkeBlayze
root@transmission:~ # ifconfig
options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
groups: lo
epair0b: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
ether 14:b3:1f:03:aa:47
hwaddr 02:1d:d0:00:07:0b
inet 192.xxx.x.x netmask 0xffffff00 broadcast 192.xxx.x.xxx
nd6 options=1<PERFORMNUD>
Media: Ethernet 10Gbase-T (10Gbase-T <full-duplex)
status: active
groups: epair
tun0: flags=8010<POINTOPOINT,MULTICAST> metric 0 mtu 1500
options=80000<LINKSTATE>
groups:tub
rknaub
I am having an issue with Lidarr. Yesterday I tried to update mono and it broke my jail, so I deleted the entire jail, followed this guide and reinstalled the latest version of Lidarr on an 11.3-Release jail, and everything seemed to be working fine, except when I choose my root folder. It allows me to select the correct folder, showing all my artist folders inside - but it shows unavailable after I select it and I cannot for the life of me figure out why.
I am seeing this in the log:
20-3-22 17:49:34.9|Warn|LidarrErrorPipeline|Invalid request Validation failed:
-- Folder is not writable by user lidarr
I have tried to chmod -R 777 the music folder but that's not working.
I have not yet tried to update Mono on this install as I am struggling with that still.
FreeNAS 11.3-U1
Lidarr 0.7.1.1381
NasKar
groups: lo
options=8<VLAN_MTU>
status: active
groups: epair
groups:tub
Your have tun0 interface so that is not the problem.
Must be a problem with your openvpn.conf file
Not familar with
but make sure the are files in that location and they are setup properly
finally make sure your auth-user-pass /mnt/JAILHD/............................./ file exists and contains the correct username and password
look in /var/log/messages file . That would give you clues as to what the issue is.
DarkeBlayze
Not familar with
I cannot find anything in the message file, i've created the update-resolv-conf. i have made sure there is a file for auth-user-pass and that the user and pass is correct. think im stuck.
rknaub
FreeNAS 11.3-U1
Lidarr 0.7.1.1381
I have fixed this problem, by installing an older version of Lidarr. And then broke it again by simply updating through the Web UI.
NasKar
If you want you can try the script I wrote to do the install. It changes the transmission user from transmission to media to match the user of my other apps. Or you could look at it for clues as to what your doing incorrectly.
FakeTracker0
Whenever I attempt to update Radarr I get the error:
    Error occurred while executing task ApplicationUpdate: ApplicationName='mono', CommandLine='--debug /tmp/radarr_update/Radarr.Update.exe 79445 /tmp/radarr_update /usr/local/share/radarr/Radarr.exe /data=/usr/local/radarr /nobrowser', CurrentDirectory='', Native error= Cannot find the specified file
    System.ComponentModel.Win32Exception (0x80004005): ApplicationName='mono', CommandLine='--debug /tmp/radarr_update/Radarr.Update.exe 79445 /tmp/radarr_update /usr/local/share/radarr/Radarr.exe /data=/usr/local/radarr /nobrowser', CurrentDirectory='', Native error= Cannot find the specified file
      at System.Diagnostics.Process.StartWithCreateProcess (System.Diagnostics.ProcessStartInfo startInfo) [0x002dc] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0
      at System.Diagnostics.Process.Start () [0x0003a] in <b3922b7d60404fa9ae645f1fb97f5b6b>:0
      at (wrapper remoting-invoke-with-check) System.Diagnostics.Process.Start()
      at NzbDrone.Common.Processes.ProcessProvider.Start (System.String path, System.String args, System.Collections.Specialized.StringDictionary environmentVariables, System.Action`1[T] onOutputDataReceived, System.Action`1[T] onErrorDataReceived) [0x00194] in <7084924a59f8492b9528f8e6bea68198>:0
      at NzbDrone.Core.Update.InstallUpdateService.InstallUpdate (NzbDrone.Core.Update.UpdatePackage updatePackage) [0x00245] in <28071e62f2f449e682962e05af20a3d7>:0
      at NzbDrone.Core.Update.InstallUpdateService.Execute (NzbDrone.Core.Update.Commands.ApplicationUpdateCommand message) [0x00071] in <28071e62f2f449e682962e05af20a3d7>:0
      at NzbDrone.Core.Messaging.Commands.CommandExecutor.ExecuteCommand[TCommand] (TCommand command, NzbDrone.Core.Messaging.Commands.CommandModel commandModel) [0x000ec] in <28071e62f2f449e682962e05af20a3d7>:0
      at (wrapper dynamic-method) System.Object.CallSite.Target(System.Runtime.CompilerServices.Closure,System.Runtime.CompilerServices.CallSite,NzbDrone.Core.Messaging.Commands.CommandExecutor,object,NzbDrone.Core.Messaging.Commands.CommandModel)
      at System.Dynamic.UpdateDelegates.UpdateAndExecuteVoid3[T0,T1,T2] (System.Runtime.CompilerServices.CallSite site, T0 arg0, T1 arg1, T2 arg2) [0x00110] in <07a075f1d23046ea85ee23d71b0a0a37>:0
      at NzbDrone.Core.Messaging.Commands.CommandExecutor.ExecuteCommands () [0x0008c] in <28071e62f2f449e682962e05af20a3d7>:0
Looking on the forums, it seems the best way to resolve this is to add a link in radarr for mono.
I've tried in the jail
ln -s /usr/local/bin/mono /bin
and outside the jail:
 iocage exec radarr ln -s /usr/local/bin/mono /usr/bin/mono
In both cases I'm running as the root user.
Any suggestions on how to fix this? I checked and I have my radarr data set as not read-only.
Details: FreeNAS 11.2-U7, I did install radarr through the plugin system initially. radarr Version: 0.2.0.1358; Mono Version: 5.10.1.57 (5.10.1.57 Tue Dec 10 07:40:49 UTC 2019)
DarkeBlayze
So as an update, I fixed OpenVPN. My biggest problem now is for some reason transmission is being denied access to settings.json and i can't for the life of me figure out why.
DarkeBlayze
when i made the directory it somehow become /config/config/transmission home. no wonder. I will hold off commenting again unless i get really stuck. Thanks for all your help @NasKar and @1ccs-todd
stalker
I'm having trouble getting Plex to work. All the other plugins & jails work just fine, but for some reason Plex appears to break.
I can get the jail to start and get to the Plex WebGUI, but this only lasts for a few minutes at the most. The jail keeps chugging along but the webgui just dies on me.
Anyone else in a similar position?
stalker
A little more digging around and this appears to be happening only when I assign a static IP to the jail. DHCP makes the issue go away :-|
RobTheRed
I've been fighting with the Lidarr install for a while. I've tried using Nano and EE to create the rc.d file for Lidarr, but when I run the last line (iocage exec Lidarr service lidarr start) I keep getting
Starting lidarr.
su: /bin/csh: Permission denied
/usr/local/etc/rc.d/lidarr: WARNING: failed to start lidarr
Command: service lidarr start failed!
I've tried to even delete the jail and recreate but it seems to still fail. Any suggestions? (I know it's a capital Lidarr... I capitalized the Jail to match my other jails)
I'm not sure what I did differently... Jackett is working for me. I've even copied Jackett's style of rc.d file and it's still not working.
afmiller
thought on "pkg.freebsd.org could not be reached via DNS, check your network:". trying to install a iocage. I can ping both google.com and 8.8.8.8, in the freenas box and whenever I create a jail via GUI.
Keeps failing everytime I try to install plex
Also verified in the resolv file that the google DNS are showing
afmiller
Attached are files of Network global, me showing ping works inside the jail itself and my resolve config file with no luck
Default gateway is 192.168.30.1 , freenas box is 192.168.30.119
