I have installed Sonarr, Radarr, Lidarr, Sabnzbd and Tautulli in separate iocage jails as per this Resource.
I want to have an easy way to install the apps in a separate jail as per the Resource link, as well as an easy way to backup and restore the separate data directories for them. You have to create multiple config files as per the README.md files this way you can do a 'git pull' to update if I make changes to the code without disturbing the unique settings for you setup. I've tested them on FN 11.1U5 Virtual Machine and they work. Feel free to leave me any feedback or bugs you encounter.
Install scripts
Backup/Restore scripts
Bonus
Install Plex
Backup/Restore Plex
Install scripts
Bonus
Install Plex
Backup/Restore Plex
