I'm in the process of putting together a NAS around the SuperMicro X9SCM.
Ill probably start off using something like the G2020, unless I can find a e3-1220 on the cheap (unless its really needed)
I would like to do zfs and raidz2.
Now, I never dealt with making a raid before, so what I would like to know is..
Am I able to start off with 1 drive, then pick up a new drive each month or so.
Once I have two extra drives (3 total) switch to raidz2 (seen somewhere that you can do it with 3, correct me if I'm wrong. I know with It would still look like I only have the size of 1)
Then add a 4th and 5th over time, maybe up to 6 if needed?
Is going about it like this easy, like "hey NAS you have a new dive have fun", or would each time I add I drive would I have to back up then format everything?
Would it be better to just use the 1 till I have 5 ?
Is there something I can run on my desktop (task bar) and maybe phone (android) to monitor the NAS in case a drive fails or another issue?
Another thing I would be interested in doing is also using this as an NVR (on different drives) with at least 4 cams. Is there a freenas plugin or a way to do this? (a parts list or built thread would be helpful too) I'm guessing it this is possible the xeon would be the way to go.
