synio
- Dec 13, 2022
I'm thinking about building a NAS based on TrueNAS SCALE.
But this would be my first time building a hardware system from scratch.
I'm also not familiar with ZFS and NAS in general.
What I am looking for in a NAS:
- Media storage (video, audio, photo) accessible from SMB, NFS etc
- Play videos stored on NAS on smart TV
- Secure local back-ups of work and private data
- Share documents in internal network using something like NextCloud
- Home Assistant with Node-Red and USB peripherals (RF transmitter, Zigbee stick...)
- Maybe CCTV for the cameras around our house
- Maybe use it to quickly deploy local development version of web projects through Docker
Reasons I would prefer TrueNAS over off-the-shelf like Synology:
- I'm an advocate of using open source technology and the freedom it gives you
- Feeling that Synology would not be as flexible or configurable
- Feeling that Synology might not be performant enough for some of my requirements
- Rather high cost if you look at the actual hardware you are ending up with
Reasons I would prefer TrueNAS SCALE over CORE:
- I have a lot of experience with server-side Linux, and Debian specifically
- I want to run Dockerized apps (like Home Assistant) with USB pass-through (SCALE Bluefin RC)
Current hardware and configuration I have in mind:
- This is based on the information in the `2021-01 Edition Revision 2a` document.
- Fractal Design Node 804 cube case (micro-ATX) (because I would prefer a smaller case and it looks pretty good, although a bigger case would certainly be acceptable too if that would be much better in terms of performance for same price or lower cost for same performance)
- Supermicro X11SSM-F Intel® C236 LGA 1151 (because it was one of the recommended motherboards in the document, I don't really have a strong preference over any, I want to start out with 2 disks but perhaps maybe later I would like to add 2 more)
- Intel® Core™ i3-9100F Processor (because it supports ECC memory, and I think it's the latest i3 generation that works with LGA 1151 motherboards?)
- Crucial MTA9ASF2G72AZ-3G2R 16 GB ECC DDR 4 3200 MHz UDIMM (16 GB ECC memory, single module because I might want to add another 16 GB module in the future)
- Seasonic Focus GX-550 PSU (because I read that 550W should be more than enough for my requirements, and 550W is the lowest I could find today)
- Samsung 870 EVO 2,5 inch 250GB SSD (for booting TrueNAS SCALE, I think I also might need an extra cable to connect it to the motherboard?)
- 2x WD Red Plus 3,5" NAS HDD (for storage, in RAID-1 configuration, thinking about getting 4 TB right now since that would be more than enough right now)
Questions:
- Could TrueNAS SCALE be a valid choice for me?
- Can I use newer hardware or would that not be a good idea? for example newer generation i3? because I found some i3 and i5 newer generations that also support ECC memory but then another motherboard would be required instead of `LGA 1151`, but I don't really understand all the implications of that. So right now I have focused on the recommendations in the `2021-01 Edition Revision 2a` document for my hardware choices.
- Does it matter that the memory is 3200 MHz and the motherboard mentions 2400 MHz? I thought not, but that speed would then be limited to 2400 MHz? I couldn't easily find ECC ram modules for 2400 MHz specifically.
- For my intended usage, would the hardware choices be OK, or is something overkill or should I upgrade something?
- Do I need anything else in terms of hardware? maybe some extra cables as well?
- Would RAID-1 make most sense? The data is not *super* important, but I do want to have a full back-up disk available when one of the disks fails, which is why I wanted to go with RAID-1. I also read about RAIDZ1 but I feel like it wouldn't make much sense to use that instead of RAID-1 for my usecase?
Thanks if you want to look into it and give me some advice.
Questions:
