enzymatic_catalysis
- May 11, 2017
Hello everyone, I'm upgrading my server setup after about a year of managing/sharing media and personal files on a Raspberry Pi 3 attached to a dual-enclosure JBOD arrangement of 2x 3TB WD Reds. The enclosure recently gave out on me (the drives are fine) so I've decided it's time for a solid upgrade, and FreeNAS seems like a good way forward. To get some insight from you experienced folks, I'll describe my expected usage for this machine, my draft of a parts list, and some related questions.
Expected Usage/Needs: I'd like to make better use of Plex, specifically to have the ability to transcode 1080p for up to 3 concurrent streams, although most often it will only need to transcode 1 stream at a time. In addition to Plex, I want the server to be running other plug-ins for automated access to Usenet 24/7. Finally, I'd like to have more confidence in my methods of data encryption and storage. Previously, I was manually encrypting (ecryptfs) and mirroring (rsync) my important files between my two drives, and then uploading these to CrashPlan as my off-site backup.
Current Build:
CPU: Intel - Xeon E3-1230 V5 3.4GHz Quad-Core Processor
MOBO: Supermicro - MBD-X11SSM-F-O Micro ATX LGA1151 Motherboard
RAM: Kingston - ValueRAM 32GB (2 x 16GB) DDR4-2133 Memory (ECC; Unregistered)
Boot Device: Sandisk - SSD PLUS 120GB 2.5" Solid State Drive
Storage: 4x or 6x 3TB WD Red in RAID-Z2 (haven't decided yet, see questions below)
Case: Fractal Design - Node 804 MicroATX Mid Tower Case
PSU: SeaSonic - 450W 80+ Gold Certified Semi-Modular ATX Power Supply
Questions:
1) Do my build specs reasonably meet my stated needs, and if not then what downgrades/upgrades should I include?
2) Am I able to combine the two 3TB WD Reds I currently have (one-year old) with two new 3TB WD Reds into RAID-Z2, and is this a decent idea to mix old and new drives of the same type?
3) Assuming I include my two used 3TB WD Reds into my FreeNAS, are there recommended ways of transferring/un-encrypting the data off these drives (EXT4 file system) for eventual transfer to the FreeNAS? The only solution I can think of is to download my files from CrashPlan onto the new system.
Mod note: Edited to remove pcpartpicker link
- Ericloewe
Current Build:
Questions:
- Ericloewe
