04/13 Edit:
I have purchased the following:
Motherboard: $35 Supermicro MBD-X10SLH-F-O
Case: $98.29 Fractal Node 804
HDD: $750 5-5TB Red Drives (Removed from element enclosures) Will be Raid Z2
Power Supply: $59.99 Rosewill CAPSTONE 450W Modular
USB: SanDisk Cruzer 16GB (USB 2.0)
CPU: $110.00 Intel i3-4350
RAM: $86.99 Samsung 8GB DDR3-1600 M391B1G73QH0-YK0
UPC: $91.48 CyberPower CP850AVRLCD
Total Cost: $1231.75
I am currently in the process of running badblocks on all of my drives. Looking forward to moving data to the system starting this weekend. I placed an order for another 8GB stick of RAM. Is there any reason why I need to wait for the other 8GB stick to come before starting the data transfer? If freenas runs out of memory will it just run slower or will there be data corruption? I am planning to use this system as a plex server and would like to use it this weekend. If I get poor performance for a few days that is fine but I am more worried about data integrity.
Original Post:
Working to put together system to run freenas. Read through the stickies and just wanted to run this build by everyone. I will be using it as a plex server and to backup family photos and videos. Plex will be accessed by a rasplex and possibly 2 android devices. Planning to purchase the following:
Motherboard: Supermicro MBD-X10SLH-F-O
Ram: Samsung 8GB DDR3-1600 MHz PC3-12800 240-pin ECC Server Memory - M391B1G73QH0-YK0
HDD: 3x 4TB Western Digital Red Drives
Case: Fractal Node 804
Power Supply: Rosewill CAPSTONE 450W Modular
USB: SanDisk Ultra Fit 16GB (USB 3.0)
CPU: Intel i3-43XX
Original Post:
CPU: Intel i3-43XX
- Can I use USB 3.0 as the boot drive? I've read a few things that it can cause issues but I'm unsure if that is an old problem or still an issue. If so I'll get a USB 2.0 Drive.
- Power Supply: I believe 450 Watts is adequate.
- CPU: Not really deadset on anything at this time. Was thinking to purchase any i3. Is there any advantage in the i3-43xx vs i3 41XX? Should my motherboard support either CPU out of the box. Read something about firmware version 2.0 or something but can't find it anymore.
- UPS: Any recommendation on one that would work well? Would like to keep it less than $100. I would need one that would allow the NAS to properly shutdown.
