Hello again,
I've been off thinking (or making more problems) I find the whole sockets and chipsets compatibility thing confusing.
My research says the i3 9100 has ECC Support and the E3C246D4U has ECC support and should take the 9th gen i3 with the latests bios?
jgreco says I can tune down CPU if I find the power draw to high. With all that considered will this build work?
CPU
Intel Core i3-9100 3.6 GHz Quad-Core Processor $211
Motherboard
ASRock E3C246D4U Micro ATX LGA1151 Motherboard $427.90
CPU Cooler
be quiet! Dark Rock 4 CPU Cooler $116
Memory
Micron 16GB DDR4 ECC 2666MHz RDIMM x 2 @ $199.00/each
Case
Fractal Design Define R5 $199.00
wanted the node 804 but all gone in australia
Power Supply
be quiet! Pure Power 11 FM 650 W 80+ Gold Certified Fully Modular ATX Power Supply $139.00
Wired Network Adapter
OEM Intel X550-T2 10G $370
Case Fan
be quiet! Silent Wings 3 59.5 CFM 140 mm Fan x 3 @ @29/each
Total $1950 ~ exchange rates and shipping variables
jgreco, whats the chance you can hold my hand through the under clocking if its required down the line?
I'm out of my depth, considerably. Would like to get parts ordered before Australia runs out of everything.
Thanks again and sorry for the partial bump.
CPU
Motherboard
CPU Cooler
Memory
Case
Power Supply
Case Fan
