Hello Wonderfull people,
I've have never "built a PC" and there is so much to learn and not sure I can catch up. Every time I think I have a good combo worked out I find a post about an issue of some component or driver and start looking for a new combo. Is there a perfect solution, I doubt it or there would be a sticky at the top saying BUILD THIS.
Now after lurking the forums and coming across 2 problems for every 1 solution I find I am turning to you for advice, recommendations and wisdom.
What I am after.
1: Fast and big ZFS storage looking to direct connect 10gbe (jumbo frames) from NAS to main computer then have the NAS sit on the router (1gbe or WiFi) for slower operations like backing up the computers in the house, macs via TimeMachine & a PC. Really its just fast and big SMB with 1 real client.
2: Has to be quiet and cool. I don’t have a server room, a cellar or anywhere I can forget about noise and heat. I don't want to hear this thing unless the HDD array is being hit. My house is hot enough (Australia) already without running a small heater in a small room 24/7.
3. Also would like to run Jellyfin, Pihole & Pfsense, for reasons
4: Reliability now and if possible future proofing to 40gbe NIC when that type of gear becomes affordable.
I have on hand
1 x Sonnet 1-Port Solo 10G Ethernet PCIe 3.0 card, currently in the old, soon to be replaced mac pro. It can be can be repurposed if needed.
And due to a very bad experience with QNAP the following storage too
6 x Segate IronWolf pro 8TB
2 x Samsung 980 pro 500gb M.2
With the above in mind I have looked at build sizes from mini ITX through to E ATX, sorry if I get my terms all muddled but I’ve only been researching the PC world for about 10 days.
I looked at the off the shelf offerings from TrueNAS, very expensive here in OZ with no local supplier. After the horrible experience I've just had with QNAP I would hate to be returning gear internationally.
So I started with components that sort of matched the specs of the of the Mini XL and I got super carried away putting combinations together... sorry.
My first 4 builds would use the same base configuration bellow
RAM: Micron 32GB DDR4 ECC 2666MHz RDIMM $329
PSU: be quiet! SFX-L Power 500W 80+ $139
Case: SilverStone DS380 12 3.5 bays total $249
Cooler: Noctua Nh-u9b-se2 $170
Fans: Noctua NF-S12A PWM x 3 $107
$994 AUD + Shipping and all the little extras
Some might need a HBA
OEM LSI 9201-16i 6Gbps 16P SAS HBA ? $286
Build A:
Board: ASMB-260T2-22A1 4 channel 8 Core $1204
Pros: 2 x onboard 10gbe + 1gbe (RJ45s), 8 x SATA, ECC, SFF, low TPD
Cons: Only 1 x m.2 so mirrored system? Non upgradable CPU, PCIe x 4 too slow for future 40gbe?
Build B:
Board: Supermicro A2SDI-H-TF-O $1202 AUD shipped
is this what they use in the Mini XL +?
Pros: 2 x onboard 10gbe + 1gbe (RJ45s), 12 x SATA, ECC, SFF, low TPD
Cons: US Board supplier (warranty issues), Only 1 x m.2 so mirrored system? Non upgradable CPU, PCIe x 4 too slow for future 40gbe? 8 of the SATA channels are from a SoC controller that I have read might have issues with TrueNAS?
Build C:
Board: ASRock Rack Intel Xeon D1541 SoC $1865
Pros: 1 PCIe 3.0 x 16 slot, 1 PCIe 3.0 x 8 slot, 2 x M.2, ECC, SFF, low TPD
Cons: 45w CPU, 2 x 10G fiber, SFP+ (need adapters), Needs a HBA to run enough
Build D:
Board: ASRock X470D4U2-2T Micro $765
CPU: AMD Athlon 3000G $129
Total $894
Pros: 2 x onboard 10gbe + 1gbe (RJ45s), Two PCIe 3.0 x 8 slot, 2 x M.2, ECC, SFF, CPU 35w TPD, future 40gbe NIC possibility?
Cons: US Board supplier “warranty issues?”, Only 2 cores on CPU, Will need a HBA to run enough drives
Build E:
Board: Z490D4U-2L2T $988
CPU: Intel Core i5-10500T $300 AUD approx.
Cooling: be quiet! Dark Rock 4 CPU Cooler $119
RAM: G.Skill 32G (2x16G) F4-3200 $179
Total $1586
Pros: 2 x onboard 10gbe + 1gbe (RJ45s), 1 x PCIe 3.0 x16 + 1 x PCIe 3.0 x8 + 1 x PCIe 3.0 x1, 2 x M.2, SFF, CPU 35w TPD, future 40gbe NIC
Cons: z490 chipset already stuck at 10th get CPU?, Non ECC, hard to find CPU, Will need a HBA to run enough drives
Leaving the microATX idea and thinking “big” opens up possibilities but limits desk space :(
Looking at 3 cases
1# be quiet SILENT BASE 802 $219
Pros: Looks easy to build in, USB C, 7 x 3.5 bays & 3 x 2.5 bays + includes ok fans
Cons: need to purchase 4 x be quiet! HDD Cage $19 each to fill it up
2# be quiet! Dark Base Pro 900 v2 $399
Pros: Looks easy to build in, USB C, 7 x 3.5 bays & 2 x 2.5 bays + includes good fans, bonus 2 x 5.25 ODB that can pack another 3 x 3.5 via a SilverStone FS303B 2 x 5.25" to 3 x3.5" $109
3# Fractal Design Define R5 Black ATX $189
Pros: 8 x 3.5 bays & 2 x 2.5 bays, bonus 2 x 5.25 ODB that can pack another 3 x 3.5 via a SilverStone FS303B 2 x 5.25" to 3 x3.5" $109
Cons: Only 2 average fans, no USB C
Build F:
Board: Supermicro MBD-C9Z590-CG $1200 AUD approx.
Total $1586
Pros: z590 chipset, PCIe 4.0, 1 x PCIe x16 + 1 x PCIe x8 + 1 x PCIe 3.0 x1, 3 x M.2?
Cons: 1 x 10gbe Marvell AQC113C, Non ECC, only 4 SATA, hard to find CPU, Will need a HBA to run enough drives
Build G:
Board: GA-Z590-AORUS-MASTER $299
Cooling: Noctua NH-U9B SE2 $107
Total $885
Pros: z590 chipset, PCIe 4.0, 1 x PCIe x16 + 1 x PCIe x8 + 1 x PCIe 3.0 x4, 2 x M.2 PCIE 3.0 + 1x M.2 PCIe4, WIFI 6, USB C
Cons: 1 x 10gbe Marvell AQC113C, Non ECC, only 6 SATA, hard to find CPU, Will need a HBA to run enough drives
My noobnees knows no bounds! Perhaps as I researched I started to make more sensible systems and just maybe the last one "G" is best bang for buck with semi future-proofness.
Having no idea what goes into the "building' part what type what extra cabling and thermal pastes and such might I need to complete the physically assemble this box as I have really never done this. Are there other bits I need to order at the same time?
Kind regards,
Owen.
What I am after.
I have on hand
Build A:
Build B:
Build C:
Build D:
Total $894
Build E:
Total $1586
Looking at 3 cases
Build F:
Total $1586
Build G:
Total $885
Kind regards,
Owen.
