Filesystem full problem
karnalta
I am trying to install PHP / MySQL on my FreeNAS computer but I always get error when trying to add the PHP package.
The following command return me "Write failed - Filesystem full !"
#pkg_add -r php5
I don't think my USB thumb is full, it's a 4gb one, and I just have FreeNAS and Transmission-daemon installed on it. How can I check the available space on my USB thumb with FreeNAS ?
Anyone could help me ?
Thank you.
ProtoSD
Even though you have a 4GB flash drive, unless you compile a custom image, FreeNAS only creates a 2GB partition which is already close to being full. Adding all the stuff you mention will easily fill it up. The extra 2GB on your flash drive is not accessible or usable. Do a seach about expanding and recompiling your image. I'll put a link here later when I get time. Also... The package database is not installed on FreeNAS, so if you add the wrong package you can't just do pkg_del, you'll have to guess at which files to remove.
