Chris Dill
- Jan 1, 2014
When I download a torrent through transmission, I specify the location as /mnt/video. This same folder is mapped into my Plex. Once the download finishes, I import into Radarr. Radarr renames the folder and file nicely, but leaves the original in place. So now I have duplicates. This same behavior happens if I add shows through Radarr directly... They download into /mnt/video then Radarr copies them to a good naming convention, but leaves the original.
How is this supposed to work? Do I instead download torrents to a seperate folder which Radarr also has access to? Then I think Radarr would copy the folder and file into /mnt/video and leave the original to seed? If this is the case, how do I get Radarr to move the file- do I need to manually edit and manually move the file?
