bumcheekcity
- Feb 5, 2021
I've installed radarr, sonarr, lidarr and nzbget as plugins with separate jails in the GUI of TrueNAS 12.0.
Lidarr doesn't work, even though the plugin is running, but the other three programs are accessible through http://192.168.0.2:6789 etc. and show up in a web browser fine. I can come back to Lidarr later, that's my lowest priority. Each of the jails is set up with NAT and VNET ticked in the options, and everything else as default.
For radarr and sonarr, i've set up mount points from /mnt/pool05/tv to /mnt/pool06/iocage/jails/sonarr/root/mnt/tv and a similar one for movies for radarr. This has allowed me to import my existing movies and TV completely successfully. I've added indexers and the NZBGet download client into both programs and every single items passes the internal tests.
When I try to download anything in either program, the file gets correctly added to NZBGet and downloaded, and I can see through directly examining the iocage folder that the intermediate files are being downloaded as NZBGet reports them.
The only log item that's an error (in NZBGet) is:
After that, it seems to consider the download failed and removes it. Any advice on how to proceed?
Unpack for Legitimate.Linux.ISO.iNTERNAL-DVDRip.XVID-8BaLLRiPS failed.
