FAQ: Migrating from FreeNAS Corral to FreeNAS 9.10 / 11
Ericloewe submitted a new resource:
FAQ: Migrating from FreeNAS Corral to FreeNAS 9.10 / 11 - Information on how to deal with the migration from FreeNAS Corral to the supported branch of FreeNAS
As per the recent announcement, FreeNAS Corral is effectively not going to see any further development.
A large number of questions has popped up and I will try to answer them here, to avoid duplication and to save everyone some trouble.
What's going on?
FreeNAS Corral had a rocky launch period. iXsystems has decided to focus on the 9.10 branch and use that as the...
Read more about this resource...
tulth
If I change aclmode from discard_chmod to restricted on a smb share without sidegrading to 9.10.x will I have problems with the share if I continue to run FreeNAS Corral?
Background:
I located 3 datasets on my FreeNAS Corral server that have aclmode set to discard_chmod.
I would like to run 9.10.x when I get time and a plan together.
If I go ahead and fix these aclmodes will I have problems on Corral?
wblock
Documentation Engineer
It probably will interfere with VM operation, specifically stuff trying to access SMB shares. Or would, except Corral might silently change it back.
There's no real reason to change the aclmode before you're ready to move to 9.x/11, so it's not something I'd worry about.
vikozo6
jerryjharrison
I have successfully moved from corral back to 9.10.2-U3, however there is a directory on the root of my zfs pool called ".vm-cache" It has a successive set of empty directories under it called "freebsd-12-zfs", and one under that called "os".
I suspect that this is a left over from my corral testing, and want to remove it. When I execute "rm -R .vm_cache" I get the error "Device busy"
Any ideas on how to clean this up?
jerryjharrison
Update to this. I used umount -f .vm_cache to clear the error, and then all of the directories were deletable, however I then get the following errors, for each of the directories, appearing in the console:
May 4 06:23:07 corral1 collectd[68307]: statvfs(/mnt/zpool1/.vm_cache/freebsd-12-zfs/os) failed: No such file or directory
May 4 06:23:17 corral1 collectd[68307]: statvfs(/mnt/zpool1/.vm_cache/freebsd-12-zfs/os) failed: No such file or directory
By recreating the directories, the error goes away. If I delete the directories again, the error reappears.
Any assistance is appreciated!
Amir Yalon
The section about encrypted pools can be updated based on the resolution of issue 23444, or at least provide a link to it. Thanks!
Ludensen
Corral's weird ACL mode-question
As I had a faint memory of accidentally turning the ACL mode on (misreading the option) I wanted to do the test described in https://forums.freenas.org/index.ph...ng-from-freenas-corral-to-freenas-9-10-11.36/
My poor HP N54L NAS - after working for a looong time to implement the change - had to undo the change which took just as long...
Now I have 2 questions:
1:
Having changed to and back from "Corral's weird ACL mode" - do I still have a problem?
2:
executing the command:
zfs set aclmode=oops dataset
Unfortunately in my case the message includes discard_chmod.
BUT executing:
zfs set aclmode=restricted dataset
and afterward testing again with:
still gives me a message including discard_chmod.
Actually executing
on ANY of my datasets gives me a message including discard_chmod...
So my guess is, this command can only be used as an initial test.
Is there a command or way that can show the problem has been remedied? :)
Backstory:
Had a NAS running Corral 10.0.4 witout problems - and planning on leaving it like that until 11-stable (If it ain't broken, don't fix it!). ZFS not upgraded and I had a 9.10 boot environment, I could use when upgrading later.
But then my Kingston USB3 boot-stick became corrupted - "only" 5 errors when scrubbed, but I wasn't able to boot any of the 5 boot environments on the stick.
Fun fact:
To test the Corral ACL mode I have installed 10.0.5 on a fresh USB-pen.
Corral 10.0.5 reports 10.0.4 as an upgrade!???
What fact or message on the forum have I overlooked? o_O
That's always going to be there on Corral on pools that support it. It's an indication that it might be in use, not a guarantee.
Haven't seen anything, but if you set the aclmode, it's going to be fine (assuming it completed successfully, in other words, that it didn't output anything).
They're the exact same build, except for the installer, which got a fix in .5.
Ludensen
Thank you @Ericloewe
Now I have actually imported the pool on a 9.10 boot-stick without problems. (Nice with backup of older settings files)
No output! So I cross my fingers and hope I will not encounter any surprises down the road!!!
Lately I've been haunted by Murphy and his law :-( Slowing my work down here before BSDCan. My backup coverage is a little thin right now. A couple of hdd's in a fireprof safe must do until I get back and can rebuild everything...
CatSailor
My FreeNAS box lost power recently (I was running the last release candidate 10 prior to the Corral release) and would not load up. After working on it I determined that now may be a good time to move to RC11. Of course the update failed and I ended up re-installing 11 from scratch.
When I logged in to RC11 it attempted to import my existing ZFS pool and this failed. I currently have a situation where looking at the "Reporting" section it shows my directories, however, i am unable to import the Volumes (in the storage tab) and do not have access to the data. I'm a little freaked out about loss of access to the data any suggestions?
*Edit - Restarted box and the volume was able to be imported. Scary but appears to be working now so all good!
