I'm new to FreeNAS, and am trying to see if I can get some help getting more detail on this alert message, and gui alert
The red alert also shows this from the web page.
Wondering what I might need to do here to troubleshoot further.
Here is the result of
145709 (boot + 26s/ENCL/CRIT) - Enclosure PD 0a(c Port 0 - 3/p1) fan 1 failed 145713 (boot + 26s/ENCL/CRIT) - Enclosure PD 0a(c Port 0 - 3/p1) fan 3 failed 145711 (boot + 26s/ENCL/CRIT) - Enclosure PD 0a(c Port 0 - 3/p1) fan 2 failed
The boot volume state is ONLINE: One or more devices has experienced an error resulting in data corruption. Applications may be affected.
zpool status -v
errors: No known data errors pool: freenas-boot state: ONLINE status: One or more devices has experienced an error resulting in data corruption. Applications may be affected. action: Restore the file in question if possible. Otherwise restore the entire pool from backup. see: http://illumos.org/msg/ZFS-8000-8A scan: scrub repaired 0 in 0h5m with 1 errors on Thu Jan 25 03:50:43 2018 config: NAME STATE READ WRITE CKSUM freenas-boot ONLINE 0 0 0 da0p2 ONLINE 0 0 0 errors: Permanent errors have been detected in the following files: freenas-boot/ROOT/default@2015-09-16-10:47:51:/usr/local/lib/libicudata. so.53.1
