Which device has experienced an error?
Bostjan
When I ran zpool status I get
One or more devices has experienced an error resulting in data corruption. Applications may be affected.
How and where can I find out which device?
1st run of
# zpool status –v
pool: tank
state: ONLINE
status: One or more devices has experienced an error resulting in data corruption. Applications may be affected.
action: Restore the file in question if possible. Otherwise restore the entire pool from backup.
see: http://illumos.org/msg/ZFS-8000-8A
scan: scrub repaired 0 in 6h27m with 0 errors on Sun Apr 26 06:27:32 2015
NAME STATE READ WRITE CKSUM
tank ONLINE 0 0 0
mirror-0 ONLINE 0 0 0
gptid/5635b592-2b8b-11e4-8622-d050991b6427 ONLINE 0 0 0
gptid/571c8555-2b8b-11e4-8622-d050991b6427 ONLINE 0 0 0
mirror-1 ONLINE 0 0 0
gptid/57c8d0a5-2b8b-11e4-8622-d050991b6427 ONLINE 0 0 0
gptid/589247dc-2b8b-11e4-8622-d050991b6427 ONLINE 0 0 0
mirror-2 ONLINE 0 0 0
gptid/a0de1680-d712-11e4-88b5-d050991b6427 ONLINE 0 0 0
gptid/a1c305d7-d712-11e4-88b5-d050991b6427 ONLINE 0 0 0
tank/.system:<0x9a>
<0x1c5>:<0xcf1c>
pool: freenas-boot
state: ONLINE
scan: none requested
freenas-boot ONLINE 0 0 0
da0p2 ONLINE 0 0 0
errors: No known data errors
Then I run
zpool scrub tank
After the scrub
# zpool status -v
pool: tank
state: ONLINE
scan: scrub repaired 0 in 6h9m with 0 errors on Tue May 19 03:32:53 2015
tank ONLINE 0 0 0
tank/.system:<0x9a>
<0x1c5>:<0xcf1c>
pool: freenas-boot
state: ONLINE
da0p2 ONLINE 0 0 0
Did you reboot since the error happened?
SweetAndLow
Sweet'NASty
Doesn't this error mean the data is completely bad and can't be fixed? You could probably delete the .system folder and reboot. After the reboot the folder should be auto created. I would test this before doing it on a live system.
Yeah. I think the error counts are zero because there was a reboot or similar situation. The file itself is corrupted, no direct way around it.
Since it's "just" the .system dataset, it's probably fixable, though.
Bostjan
It was rebooted inbetween.
- how to access the directory
tank/.system
- how to delete it?
- what is in this .system dataset? Is it really safe to delete it?
First of all, post the output of smartctl -a /dev/adaX for all drives.
Bostjan
Do you mean this?
smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p13 amd64] (local build)
Model Family: Western Digital Caviar Green (AF, SATA 6Gb/s)
Device Model: WDC WD30EZRX-00D8PB0
Serial Number: WD-WCC4N7ZFRN50
LU WWN Device Id: 5 0014ee 2b5faa069
Firmware Version: 80.00A80
User Capacity: 3,000,592,982,016 bytes [3.00 TB]
Rotation Rate: 5400 rpm
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Wed May 20 21:25:21 2015 CEST
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
data collection: (39060) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 392) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x7035) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 170 170 021 Pre-fail Always - 6475
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 10
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 099 099 000 Old_age Always - 1050
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 10
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 1
193 Load_Cycle_Count 0x0032 187 187 000 Old_age Always - 39882
194 Temperature_Celsius 0x0022 118 111 000 Old_age Always - 32
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 200 200 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
No self-tests have been logged. [To run self-tests, use: smartctl -t]
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
That drive seems ok. That leaves the other one.
Big problem, however: You haven't run any SMART tests. It's not much of a wonder you ended up in this position.
What bugs me is that the disk says it's ok, which disagrees with the fact that corruption could not be fixed...
Which leads me to the question "What exactly is your hardware?"
Bostjan
Yes I have run SMART test. Haven't I? I have set in the GUI to run SMART. Is this correct?
This is smartctl -a /dev/adaX output:
https://www.dropbox.com/s/7cu70knr8w604ff/smartctl -a -dev-adaX.txt?dl=0
FreeNAS 9.3 Stable
ASRock C2750D4I
1*8 GB ECC RAM
ada4 and ada5 do not have SMART tests set. Just edit the settings you have to add those two drives. You have to do this whenever you replace drives or add drives. For now at least.
ada1 is very dubious at the moment (18 spin retries, lots of command timeouts).
Still, I'd expect at least two dying drives, both in the same vdev. This is all rather odd, but the SMART test results for ada4 and ada5 might help. You can run them manually with smartctl -t long /dev/adaX.
Bostjan
I was also reading all this smartctl -a /dev/adaX output, but I didn't find any usefull information.
Can you please tell me which lines told you all this information.
Now I have run manually smartctl -t long /dev/ada4 and it told me that it would take 392 min to finish. Is that normal? Can I normaly use FreeNAS inbetween? Can I also at the same time run SMART test for ada5?
Bidule0hm
Server Electronics Sorcerer
Yes to all 3 questions ;)
The lines labeled spin_retry_count and command_timeouts.
