Iz Oz
- Aug 6, 2016
I recently installed FreeNAS 9.10 (less than a week ago) and strangely received the following message in my alerts.
I went ahead and did a system save (System -> General -> Save Config) and I figure that I need to get a different USB drive. I'm surprised corruption has occurred so quickly on my new USB stick (Corsair voyager).
I've been doing some reading thru the forum and it appears that most people conclude that it is a faulty USB drive which FreeNAS is running off.CRITICAL: Aug. 9, 2016, 5:58 p.m. - The boot volume state is ONLINE: One or more devices has experienced an error resulting in data corruption. Applications may be affected.
[root@freenas ~]# zpool status -v | more pool: IAO_Storage state: ONLINE scan: none requested config: NAME STATE READ WRITE CKSUM IAO_Storage ONLINE 0 0 0 raidz2-0 ONLINE 0 0 0 gptid/ca0f3da6-5a9e-11e6-a720-0cc47aac2d2c ONLINE 0 0 0 gptid/cc8b199d-5a9e-11e6-a720-0cc47aac2d2c ONLINE 0 0 0 gptid/cf0abb3a-5a9e-11e6-a720-0cc47aac2d2c ONLINE 0 0 0 gptid/d1938b22-5a9e-11e6-a720-0cc47aac2d2c ONLINE 0 0 0 gptid/d42eb46d-5a9e-11e6-a720-0cc47aac2d2c ONLINE 0 0 0 gptid/d6b12821-5a9e-11e6-a720-0cc47aac2d2c ONLINE 0 0 0 errors: No known data errors pool: freenas-boot state: ONLINE status: One or more devices has experienced an error resulting in data corruption. Applications may be affected. action: Restore the file in question if possible. Otherwise restore the entire pool from backup. see: http://illumos.org/msg/ZFS-8000-8A scan: none requested config: NAME STATE READ WRITE CKSUM freenas-boot ONLINE 0 0 12 gptid/29be3ed0-5657-11e6-b4eb-0cc47aac2d2c ONLINE 0 0 24 errors: Permanent errors have been detected in the following files: //usr/local/lib/libharfbuzz.so.0.10200.3
- Is this the correct course of action and what USB's are recommended?
- Is there a way to avoid this in the future, I read of being able to run two USB in mirror, how is this done?
- Is it ok to keep my server running or should I shut it down? I was under the impression that the USB boot was only used for booting up the system, not running it.
