Chris McDowell
- Feb 3, 2017
I got an HP SSD to replace some USB thumb drives that were degrading. Out of the box it starts degrading my boot volume . I purchased this one from NewEgg thinking it was fairly respectable brand. https://www.newegg.com/Product/Product.aspx?Item=N82E16820326780 It lists a Marvell 88NV1120 controller which I can't find much info on for support. Did I get a faulty drive or is there a compatibility issue with this controller?
I installed a fresh copy of FreeNas 11.2 RC-1 onto this drive and it would not boot with either Legacy or UEFI so I booted off a USB and mirrored to this drive but am having the degradation issues now. I swapped the USB for a HDD which is running fine except for the small amount of corruption while running just the SSD and switching the USB for the HDD.
pool: freenas-boot state: DEGRADED status: One or more devices has experienced an error resulting in data corruption. Applications may be affected. action: Restore the file in question if possible. Otherwise restore the entire pool from backup. see: http://illumos.org/msg/ZFS-8000-8A scan: resilvered 785M in 0 days 00:00:21 with 7 errors on Sun Oct 28 19:22:15 2018 config: NAME STATE READ WRITE CKSUM freenas-boot DEGRADED 0 0 7 mirror-0 DEGRADED 0 0 14 ada1p2 DEGRADED 0 0 971 too many errors ada0p2 ONLINE 0 0 14 block size: 512B configured, 4096B native errors: Permanent errors have been detected in the following files: <metadata>:<0x25> <metadata>:<0x26> <metadata>:<0x27>
