Failing drive?
SilentFox
I yesterday noted the below errors in my system alerts:
CRITICAL: March 12, 2018, 10:07 p.m. - Device: /dev/ada2, 2 Currently unreadable (pending) sectors
The scrub completed following a reboot and now I have the following errors - as can be seen the number of unreadable sectors has increased:
CRITICAL:						March 13, 2018, 12:08 a.m. - Device: /dev/ada2, not capable of SMART self-check
CRITICAL:						March 13, 2018, 12:08 a.m. - Device: /dev/ada2, failed to read SMART Attribute Data
CRITICAL:						March 13, 2018, 12:08 a.m. - Device: /dev/ada2, Read SMART Self-Test Log Failed
CRITICAL:						March 13, 2018, 12:08 a.m. - Device: /dev/ada2, Read SMART Error Log Failed
CRITICAL:						March 13, 2018, 9:22 p.m. - Device: /dev/ada2, 12 Currently unreadable (pending) sectors
CRITICAL:						March 13, 2018, 10:22 p.m. - Device: /dev/ada2, Self-Test Log error count increased from 0 to 1
CRITICAL:						March 13, 2018, 12:02 a.m. - The volume Njord-pool state is ONLINE: One or more devices has experienced an unrecoverable error. An attempt was made to correct the error. Applications are unaffected.
Running a smart test for the affected drive results in the below readout - do I need to start looking at replacing the drive?
Any help gratefully received since I don't know the threshold for replacement. Research of these forums and the first post here in particular suggests I might have an issue.
smartctl 6.5 2016-05-07 r4318 [FreeBSD 11.1-STABLE amd64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:	 Western Digital Red
Device Model:	 WDC WD40EFRX-68N32N0
Serial Number:	WD-
LU WWN Device Id: 5 0014ee 26407a93b
Firmware Version: 82.00A82
User Capacity:	4,000,787,030,016 bytes [4.00 TB]
Sector Sizes:	 512 bytes logical, 4096 bytes physical
Rotation Rate:	5400 rpm
Form Factor:	  3.5 inches
Device is:		In smartctl database [for details use: -P show]
ATA Version is:   ACS-3 T13/2161-D revision 5
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is:	Tue Mar 13 22:30:20 2018 GMT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
										was never started.
Self-test execution status:	  ( 117) The previous self-test completed having
										the read element of the test failed.
data collection:				(44160) seconds.
capabilities:					(0x7b) SMART execute Offline immediate.
										command.
										Self-test supported.
SMART capabilities:			(0x0003) Saves SMART data before entering
										power-saving mode.
Error logging capability:		(0x01) Error logging supported.
Short self-test routine
recommended polling time:		(   2) minutes.
Extended self-test routine
recommended polling time:		( 468) minutes.
Conveyance self-test routine
recommended polling time:		(   5) minutes.
SCT capabilities:			  (0x303d) SCT Status supported.
										SCT Data Table supported.
ID# ATTRIBUTE_NAME		  FLAG	 VALUE WORST THRESH TYPE	  UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate	 0x002f   164   143   051	Pre-fail  Always	   -	   1467
  3 Spin_Up_Time			0x0027   177   177   021	Pre-fail  Always	   -	   6108
  4 Start_Stop_Count		0x0032   100   100   000	Old_age   Always	   -	   10
  5 Reallocated_Sector_Ct   0x0033   200   200   140	Pre-fail  Always	   -	   0
  7 Seek_Error_Rate		 0x002e   200   200   000	Old_age   Always	   -	   0
  9 Power_On_Hours		  0x0032   093   093   000	Old_age   Always	   -	   5545
 10 Spin_Retry_Count		0x0032   100   253   000	Old_age   Always	   -	   0
 11 Calibration_Retry_Count 0x0032   100   253   000	Old_age   Always	   -	   0
 12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   10
192 Power-Off_Retract_Count 0x0032   200   200   000	Old_age   Always	   -	   5
193 Load_Cycle_Count		0x0032   200   200   000	Old_age   Always	   -	   9
194 Temperature_Celsius	 0x0022   123   115   000	Old_age   Always	   -	   27
196 Reallocated_Event_Count 0x0032   200   200   000	Old_age   Always	   -	   0
197 Current_Pending_Sector  0x0032   200   200   000	Old_age   Always	   -	   12
198 Offline_Uncorrectable   0x0030   100   253   000	Old_age   Offline	  -	   0
199 UDMA_CRC_Error_Count	0x0032   200   200   000	Old_age   Always	   -	   0
200 Multi_Zone_Error_Rate   0x0008   199   199   000	Old_age   Offline	  -	   616
SMART Error Log Version: 1
No Errors Logged
Num  Test_Description	Status				  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline	   Completed: read failure	   50%	  5545		 4145480
# 2  Short offline	   Completed: read failure	   90%	  5544		 1590694559
# 3  Extended offline	Completed without error	   00%	  5376		 -
# 4  Extended offline	Completed without error	   00%	  5352		 -
# 5  Extended offline	Completed without error	   00%	  5016		 -
# 6  Extended offline	Completed without error	   00%	  4704		 -
# 7  Extended offline	Completed without error	   00%	  4609		 -
# 8  Extended offline	Completed without error	   00%	  4273		 -
# 9  Extended offline	Completed without error	   00%	  3961		 -
#10  Extended offline	Completed without error	   00%	  3865		 -
#11  Extended offline	Completed without error	   00%	  3529		 -
#12  Extended offline	Completed without error	   00%	  3218		 -
#13  Extended offline	Completed without error	   00%	  3146		 -
#14  Extended offline	Completed without error	   00%	  2810		 -
#15  Extended offline	Completed without error	   00%	  2498		 -
#16  Extended offline	Completed without error	   00%	  2402		 -
#17  Extended offline	Completed without error	   00%	  2066		 -
#18  Extended offline	Completed without error	   00%	  1754		 -
#19  Extended offline	Completed without error	   00%	  1682		 -
#20  Extended offline	Completed without error	   00%	  1347		 -
#21  Extended offline	Completed without error	   00%	  1035		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
Please let me know if any other information is needed. Many thanks!
SilentFox
Yes, time to replace it.
Thanks for the quick response! I will initiate an RMA with WD.
So I can better understand - why do those two pieces of data in particular suggest the drive needs replacing - is any read failure a bad sign - i.e. no bad sectors are tolerable?
m0nkey_
If the SMART test is failing, then it's a clear indication that the drive itself is failing.
