today I installed TrueNAS 12.0-U1. I wanted to create a pool consisting of 2x external HDDs (1TB&320GB) via USB 3.0 for test purpose. However, I cannot do that due to the following error:
Wiping in TrueNAS did not work, so i wiped the two disks in Windows with diskpart. However, it did not solve the problem above
[EFAULT] Failed to wipe disk da1: [EFAULT] Command dd if=/dev/zero of=/dev/da1 bs=1M count=32 failed (code 1): dd: /dev/da1: Device not configured 20+0 records in 19+0 records out 19922944 bytes transferred in 141.176412 secs (141121 bytes/sec)
  File "/usr/local/lib/python3.8/site-packages/middlewared/job.py", line 361, in run
    await self.future
  File "/usr/local/lib/python3.8/site-packages/middlewared/job.py", line 397, in __run_body
  File "/usr/local/lib/python3.8/site-packages/middlewared/schema.py", line 973, in nf
  File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/pool.py", line 655, in do_create
    formatted_disks = await self.middleware.call('pool.format_disks', job, disks)
  File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1238, in call
    return await self._call(
  File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1195, in _call
  File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/pool_/format_disks.py", line 56, in format_disks
    await asyncio_map(format_disk, disks.items(), limit=16)
  File "/usr/local/lib/python3.8/site-packages/middlewared/utils/asyncio_.py", line 16, in asyncio_map
    return await asyncio.gather(*futures)
  File "/usr/local/lib/python3.8/site-packages/middlewared/utils/asyncio_.py", line 13, in func
    return await real_func(arg)
  File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/pool_/format_disks.py", line 29, in format_disk
  File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1206, in _call
  File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1110, in run_in_executor
  File "/usr/local/lib/python3.8/site-packages/middlewared/utils/io_thread_pool_executor.py", line 25, in run
  File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/disk_/format.py", line 25, in format
    raise CallError(f'Failed to wipe disk {disk}: {job.error}')
middlewared.service_exception.CallError: [EFAULT] Failed to wipe disk da1: [EFAULT] Command dd if=/dev/zero of=/dev/da1 bs=1M count=32 failed (code 1):
20+0 records in
19+0 records out
