Recently setup a test Freenas v9.2 server just to try and get a feel for it. Like most of my UNIX/Xenix/Linux experiences over the years I approached this with the same fear I get when I visit the dentist.:)
After some initial installation troubles...(mostly due to my reluctance to trawl through yards and yards of documentation) I have successfully setup the NAS environment.
S0 far I am quite impressed with performance of ZFS. However the NAS bit is not what I am interested in (I am sure this implementation would not have reached its level of notoriety if it didn't work properly). To test the jails bit I set up two jails, one for plexserver (ie a pluginJail type) and one for Calibre (a portJail type). The first attempt to install Plexserver failed crashing the server. On reboot there didn't seem to be any obvious damage so second attempt went in ok and Plex is working as it should. Installing Calibre was a little more fiddly but creating the jail, dataset, downloading and setup of package went ok. Configuration wasn't as smooth and ended up having to use root as the calibre server user which is fine for now. The main thing is that it works as it should and connecting via web browser works like a dream.
So far so good I was growing in confidence, Now for a real test; to set up a linux app by downloading and building within is own jail.In this case I wanted to setup serviio
Tried to create a third jail of type portJail, however mid way through the creation the server crashed on reboot I am left with a half baked jail. I can see the jail directory structure has been setup under volumes but there is not an entry in the jails table so I can not delete it from the webgui. It will not allow me to recreate it as obviously it exists in the directory structure.
So a couple of questions:
Can I setup multiple jails of the same type?
And, before I dive in and start hacking and slashing with a machette what is the cleanest way to remove this half baked jail and ensure that the management database is clean.
An before someone shouts 'hardware' the server is kosher. All components apart from the case are new.
AMD3 Motherboard
16gb DDR3 ecc memory
5 x WD 3Tb red label sata3 nas drives
Any help would be greatly appreciated
Bick
AMD3 Motherboard
Bick
