rfvgyhn
 - Nov 26, 2014
I'm getting the following critical errors when logging into FreeNAS:
It seems like my drive is failing/failed, but the output seems contradictory to me. Do I need to replace my drive?
Device: /dev/ada0, 1 Currently unreadable (pending) sectors Device: /dev/ada0, 2 Offline uncorrectable sectors
 smartctl -q noserial -a /dev/ada0 says PASSED but it also shows read failures. A fresh scrub shows everything is online with no errors which I would expect there to be some sort of error info.It seems like my drive is failing/failed, but the output seems contradictory to me. Do I need to replace my drive?
pool: storage state: ONLINE scan: scrub repaired 0 in 8h9m with 0 errors on Thu Nov 9 00:12:11 2017 config: NAME STATE READ WRITE CKSUM storage ONLINE 0 0 0 raidz2-0 ONLINE 0 0 0 gptid/bf0771be-7fbd-11e4-abfb-d050995afcdc ONLINE 0 0 0 gptid/c017582f-7fbd-11e4-abfb-d050995afcdc ONLINE 0 0 0 gptid/c11b84bf-7fbd-11e4-abfb-d050995afcdc ONLINE 0 0 0 gptid/c228158d-7fbd-11e4-abfb-d050995afcdc ONLINE 0 0 0 gptid/c33aac95-7fbd-11e4-abfb-d050995afcdc ONLINE 0 0 0 gptid/c44078bc-7fbd-11e4-abfb-d050995afcdc ONLINE 0 0 0 errors: No known data errors
=== START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x82) Offline data collection activity was completed without error. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: (51720) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 517) minutes. Conveyance self-test routine recommended polling time: ( 5) minutes. SCT capabilities: (0x7035) SCT Status supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 24 3 Spin_Up_Time 0x0027 194 176 021 Pre-fail Always - 7275 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 61 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0 9 Power_On_Hours 0x0032 067 067 000 Old_age Always - 24289 10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 61 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 31 193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 388 194 Temperature_Celsius 0x0022 118 104 000 Old_age Always - 34 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 1 198 Offline_Uncorrectable 0x0030 200 200 000 Old_age Offline - 2 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 2 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Completed: read failure 90% 24267 3519065096 # 2 Short offline Completed: read failure 90% 24242 3519065096 # 3 Short offline Completed: read failure 90% 24194 3519065096 # 4 Short offline Completed: read failure 90% 24193 3519065096 # 5 Short offline Completed: read failure 90% 24145 3519065096 # 6 Short offline Completed: read failure 90% 24097 3519065096 # 7 Short offline Completed: read failure 60% 24073 3519065096 # 8 Short offline Completed: read failure 90% 24025 3519065096 # 9 Short offline Completed: read failure 90% 23977 3519065096 #10 Short offline Completed: read failure 90% 23929 3519065096 #11 Short offline Completed: read failure 90% 23881 3519065096 #12 Extended offline Completed: read failure 10% 23868 3519065096 #13 Short offline Completed: read failure 10% 23833 3519065096 #14 Short offline Completed: read failure 20% 23785 3519065096 #15 Short offline Completed: read failure 10% 23738 3519065096 #16 Short offline Completed: read failure 90% 23690 3519065096 #17 Short offline Completed: read failure 90% 23642 3519065096 #18 Short offline Completed: read failure 60% 23594 3519065096 #19 Short offline Completed: read failure 60% 23546 3519065096 #20 Extended offline Completed: read failure 10% 23532 3519065096 #21 Short offline Completed: read failure 60% 23498 3519065096 SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
