websmith
- Sep 20, 2018
Hi People,
I am fairly new to ZFS and FreeNAS in particular.
I have been using ZFS on Linux for about a year in VM with a LSI SAS card in passthrough mode, but decided to set up a dedicated box for my NAS.
My build is:
My main pool:
The L2ARC is 64GB
the ZIL is 16GB
Output from top:
Output from dmesg|grep mps
So wall of text completed.
My question is what kind of write speed should I be able to expect with the above pool? I know that in raw terms, I should not expect more than 3xsingle drive write speed, since i'm running with a striped mirror zvol.
Initially I had a Intel DC S3520 SSD for ZIL/L2ARC, but exchanged it for the Optane since I hoped that the better speed would give me better write speed, but it does not seems like it.
using dd from my esxi with sync=forced:
which translates to roughly 230MB'ish write speed no matter the block size
Mounting an iscsi zvol, also with sync=forced from my windows and testing with CrystalDiskMark I get similar'ish results.
One of the reasons for going with a dedicated NAS was that I could install a 10GB netcard in my main rig and get "local like" speeds to my nas, and also for durability reasons, so my esxi server(s) could share fast storage.
I was hoping that with the above setup I could actually use the speed of the ZIL to boost my 3xmirror write speed so I could get around 600MB/s.
Is that impossible?, would I need to add three extra mirrors to my pool to get that kind of performance?
I am happy with my 900P, since the latency is extremely low on it and when the L2ARC is filled as it should be by my esxi servers, at least the esxi server will have low latency access to the nfs share, just not crazy read/write speeds.
Anything I should do differently, I have spent lots of money on this setup, which is fine, since computers is my hobby - I just need advice on how to best utilize the current gear and advice to make it better.
I have read a lot of the previous posts about performance issues and my own conclusion is that my performance will probably not be much better with the amount of hardrives i have now, but I would rather ask the experts.
Thanks in advance for any replies.
Bjorn
P.S. Yes I know I should have asked for advice before spending stacks of cash, but I wanted to learn by doing as well and spending money is no big issue (within limits)
P.P.S I have a Intel DC S4600 960GB lying on my desk that I consider buying a twin for and use for a mirrored pool for my esxi, not sure if thats worth it.
My build is:
 SilverStone CS380 (8x3.5" hot plug)
Cremax ICY Dock MB455SPF (8x2.5" hot plug)
SuperMicro X10SRi-F
1xXeon E5-1620v3 (4c, 8t)
64GB ECC REG, 4 modules so I can upgrade to 128GB if needed
1xIBM 46M0912 (M1015 i think) SAS2, 8i, flashed to IT mode, P20
1xDell H200 8i, Flashed to IT mode, P20 (Planning to use for storage pool)
1xLSI SAS 921116e flashed to IT mode, P20 (Planning to add external storage)
1xOptane 900P, PCI-e, 280GB
1xIntel X540 T2, where one port is being used for management/my use and the other port is being used as a dedicated point to point connection to my esxi server with NFS.
3xWD RED, 2TB
3x Seagate NAS 2TB
4x STEA4000400, taken out of case, not in use yet, but plan is to use them as a backup poolMy main pool:
 NAME											STATE	 READ WRITE CKSUM
tank											ONLINE	   0	 0	 0
  mirror-0									  ONLINE	   0	 0	 0
	gptid/d0195541-a267-11e8-a5cc-000c293f95ce  ONLINE	   0	 0	 0
	gptid/d101bb1c-a267-11e8-a5cc-000c293f95ce  ONLINE	   0	 0	 0
  mirror-1									  ONLINE	   0	 0	 0
	gptid/d1da3874-a267-11e8-a5cc-000c293f95ce  ONLINE	   0	 0	 0
	gptid/d29d9899-a267-11e8-a5cc-000c293f95ce  ONLINE	   0	 0	 0
  mirror-2									  ONLINE	   0	 0	 0
	gptid/efed68cb-aba1-11e8-87b7-002590a3474e  ONLINE	   0	 0	 0
	gptid/f0b4111a-aba1-11e8-87b7-002590a3474e  ONLINE	   0	 0	 0
logs
  gpt/optane-log0							   ONLINE	   0	 0	 0
cache
  gpt/optane-cache0							 ONLINE	   0	 0	 0The L2ARC is 64GB
the ZIL is 16GB
Output from top:
last pid: 93494;  load averages:  0.10,  0.24,  0.23																				   up 2+13:32:24  11:51:35
90 processes:  1 running, 89 sleeping
CPU:  0.0% user,  0.0% nice,  0.0% system,  0.0% interrupt, 99.9% idle
Mem: 156M Active, 1254M Inact, 44G Wired, 16G Free
ARC: 29G Total, 9042M MFU, 20G MRU, 20M Anon, 62M Header, 197M Other
	 27G Compressed, 46G Uncompressed, 1.70:1 Ratio
Swap: 6144M Total, 6144M Free
mps0: <Avago Technologies (LSI) SAS2008> port 0xe000-0xe0ff mem 0xfb040000-0xfb04ffff,0xfb000000-0xfb03ffff irq 26 at device 0.0 on pci2
mps0: Firmware: 20.00.07.00, Driver: 21.02.00.00-fbsd
mps0: IOCCapabilities: 1285c<ScsiTaskFull,DiagTrace,SnapBuf,EEDP,TransRetry,EventReplay,HostDisc>
mps1: <Avago Technologies (LSI) SAS2008> port 0xd000-0xd0ff mem 0xfa600000-0xfa603fff,0xfa580000-0xfa5bffff irq 40 at device 0.0 on pci4
mps1: Firmware: 20.00.07.00, Driver: 21.02.00.00-fbsd
mps1: IOCCapabilities: 1285c<ScsiTaskFull,DiagTrace,SnapBuf,EEDP,TransRetry,EventReplay,HostDisc>
mps2: <Avago Technologies (LSI) SAS2116> port 0xb000-0xb0ff mem 0xfae9c000-0xfae9ffff,0xfae40000-0xfae7ffff irq 16 at device 0.0 on pci7
mps2: Firmware: 20.00.07.00, Driver: 21.02.00.00-fbsd
mps2: IOCCapabilities: 1285c<ScsiTaskFull,DiagTrace,SnapBuf,EEDP,TransRetry,EventReplay,HostDisc>
mps1: SAS Address for SATA device = 3c2b3d30817c3f40
mps1: SAS Address from SATA device = 3c2b3d30817c3f40
mps1: SAS Address for SATA device = 382a5233918a373f
mps1: SAS Address from SATA device = 382a5233918a373f
mps1: SAS Address for SATA device = 34634434dda2be6e
mps1: SAS Address from SATA device = 34634434dda2be6e
mps1: SAS Address for SATA device = 383053306b7b5633
mps1: SAS Address from SATA device = 383053306b7b5633
mps1: SAS Address for SATA device = 34634230e4a7c06c
mps1: SAS Address from SATA device = 34634230e4a7c06c
mps1: SAS Address for SATA device = d1766451f8b9bd87
mps1: SAS Address from SATA device = d1766451f8b9bd87
da1 at mps1 bus 0 scbus1 target 1 lun 0
da0 at mps1 bus 0 scbus1 target 0 lun 0
da2 at mps1 bus 0 scbus1 target 2 lun 0
da4 at mps1 bus 0 scbus1 target 4 lun 0
da3 at mps1 bus 0 scbus1 target 3 lun 0
da5 at mps1 bus 0 scbus1 target 5 lun 0
 time dd if=/dev/zero of=./9G.bin bs=9000 count=1000000
1000000+0 records in
1000000+0 records out
real	0m 37.83s
user	0m 28.52s
sys	 0m 0.00s
time dd if=/dev/zero of=./9G_2.bin bs=1M count=9000
 9000+0 records in
9000+0 records out
real	0m 36.00s
user	0m 26.89s
sys	 0m 0.00s
time dd if=/dev/zero of=./9G_3.bin bs=4k count=2200000
2200000+0 records in
2200000+0 records out
real	0m 39.51s
user	0m 28.41s
sys	 0m 0.00swhich translates to roughly 230MB'ish write speed no matter the block size
Bjorn
