Hi
I have an HP DL380 G7 as Frereen's server, works great!
I also have an HP DL180 G6 that collects dust ...
I bought an LSI 9200-8e and put in the 380an and also bought a SAS SFF-8087 36P for the Mini SAS SFF 8088, connected it directly in the backplane on the 180an and the LSI card in the 380an.
Launches the server, FreeNAS finds disks and DL18XG6BP during startup
Jan 30 23:06:59 freenas mps1: SAS Address for SATA device = d182434fdcccda72
Jan 30 23:06:59 freenas mps1: SAS Address for SATA device = d166694be9ccbd83
Jan 30 23:06:59 freenas mps1: SAS Address for SATA device = d1645944dbdac090
Jan 30 23:06:59 freenas mps1: SAS Address for SATA device = d1645944dbbdbb92
Jan 30 23:06:59 freenas mps1: SAS Address for SATA device = d162505df0c0b895
Jan 30 23:06:59 freenas mps1: SAS Address for SATA device = d167574edacbbd88
Jan 30 23:06:59 freenas mps1: SAS Address for SATA device = d180635df2d0bb91
Jan 30 23:06:59 freenas mps1: SAS Address for SATA device = d167624bfcbcdf76
Jan 30 23:06:59 freenas mps1: SAS Address from SATA device = d182434fdcccda72
Jan 30 23:06:59 freenas mps1: SAS Address from SATA device = d166694be9ccbd83
Jan 30 23:06:59 freenas mps1: SAS Address from SATA device = d1645944dbdac090
Jan 30 23:06:59 freenas mps1: SAS Address from SATA device = d1645944dbbdbb92
Jan 30 23:06:59 freenas mps1: SAS Address from SATA device = d162505df0c0b895
Jan 30 23:06:59 freenas mps1: SAS Address from SATA device = d167574edacbbd88
Jan 30 23:06:59 freenas mps1: SAS Address from SATA device = d180635df2d0bb91
Jan 30 23:06:59 freenas mps1: SAS Address from SATA device = d167624bfcbcdf76
Jan 30 23:06:59 freenas ses0 at mps1 bus 0 scbus5 target 16 lun 0
Jan 30 23:06:59 freenas ses0: <HP DL18xG6BP 2.18> Fixed Enclosure Services SPC-3 SCSI device
Jan 30 23:06:59 freenas ses0: 300,000MB / s transfers
Jan 30 23:06:59 freenas ses0: SCSI-3 ENC Device
But then something happens
Jan 30 23:07:40 freenas (probe0:mps1:0:8:0): INQUIRY. CDB: 12 00 00 00 24 00 length 36 SMID 228 Aborting command 0xfffffe0001323b40
Jan 30 23:07:40 freenas mps1: Sending reset from mpssas_send_abort for target ID 8
Jan 30 23:07:40 freenas mps1: Unfreezing devq for target ID 8
Jan 30 23:07:40 freenas (probe0:mps1:0:8:0): CAM status: Command timeout
Jan 30 23:07:40 freenas (probe0:mps1:0:8:0): Retrying command
Jan 30 23:07:40 freenas (probe1:mps1:0:9:0): INQUIRY. CDB: 12 00 00 00 24 00 length 36 SMID 234 Aborting command 0xfffffe0001324320
Jan 30 23:07:40 freenas mps1: Sending reset from mpssas_send_abort for target ID 9
Jan 30 23:07:40 freenas mps1: Unfreezing devq for target ID 9
Jan 30 23:07:40 freenas (probe1:mps1:0:9:0): CAM status: Command timeout
Jan 30 23:07:40 freenas (probe1:mps1:0:9:0): Retrying command
Jan 30 23:07:40 freenas (probe2:mps1:0:10:0): INQUIRY. CDB: 12 00 00 00 24 00 length 36 SMID 240 Aborting command 0xfffffe0001324b00
Jan 30 23:07:40 freenas mps1: Sending reset from mpssas_send_abort for target ID 10
Jan 30 23:07:40 freenas mps1: Unfreezing devq for target ID 10
Jan 30 23:07:40 freenas (probe2:mps1:0:10:0): CAM status: Command timeout
Jan 30 23:07:40 freenas (probe2:mps1:0:10:0): Retrying command
Jan 30 23:07:40 freenas (probe3:mps1:0:11:0): INQUIRY. CDB: 12 00 00 00 24 00 length 36 SMID 246 Aborting command 0xfffffe00013252e0
Jan 30 23:07:40 freenas mps1: Sending reset from mpssas_send_abort for target ID 11
Jan 30 23:07:40 freenas mps1: Unfreezing devq for target ID 11
Jan 30 23:07:40 freenas (probe3:mps1:0:11:0): CAM status: Command timeout
Jan 30 23:07:40 freenas (probe3:mps1:0:11:0): Retrying command
Jan 30 23:07:41 freenas (probe4:mps1:0:12:0): INQUIRY. CDB: 12 00 00 00 24 00 length 36 SMID 253 Aborting command 0xfffffe0001325c10
Jan 30 23:07:41 freenas mps1: Sending reset from mpssas_send_abort for target ID 12
Jan 30 23:07:41 freenas mps1: Unfreezing devq for target ID 12
Jan 30 23:07:41 freenas (probe4:mps1:0:12:0): CAM status: Command timeout
Jan 30 23:07:41 freenas (probe4:mps1:0:12:0): Retrying command
Jan 30 23:07:41 freenas (probe5:mps1:0:13:0): INQUIRY. CDB: 12 00 00 00 24 00 length 36 SMID 258 Aborting command 0xfffffe00013262a0
Jan 30 23:07:41 freenas mps1: Sending reset from mpssas_send_abort for target ID 13
Jan 30 23:07:41 freenas mps1: Unfreezing devq for target ID 13
Jan 30 23:07:41 freenas (probe5:mps1:0:13:0): CAM status: Command timeout
Jan 30 23:07:41 freenas (probe5:mps1:0:13:0): Retrying command
Jan 30 23:07:41 freenas (probe6:mps1:0:14:0): INQUIRY. CDB: 12 00 00 00 24 00 length 36 SMID 263 Aborting command 0xfffffe0001326930
Jan 30 23:07:41 freenas mps1: Sending reset from mpssas_send_abort for target ID 14
Jan 30 23:07:41 freenas mps1: Unfreezing devq for target ID 14
Jan 30 23:07:41 freenas (probe6:mps1:0:14:0): CAM status: Command timeout
Jan 30 23:07:41 freenas (probe6:mps1:0:14:0): Retrying command
Jan 30 23:07:41 freenas (probe7:mps1:0:15:0): INQUIRY. CDB: 12 00 00 00 24 00 length 36 SMID 272 Aborting command 0xfffffe0001327500
Jan 30 23:07:41 freenas mps1: Sending reset from mpssas_send_abort for target ID 15
Jan 30 23:07:41 freenas mps1: Unfreezing devq for target ID 15
Jan 30 23:07:41 freenas (probe7:mps1:0:15:0): CAM status: Command timeout
Jan 30 23:07:41 freenas (probe7:mps1:0:15:0): Retrying command
Jan 30 23:08:40 freenas (probe0:mps1:0:8:0): INQUIRY. CDB: 12 00 00 00 24 00 length 36 SMID 285 Aborting command 0xfffffe0001328610
Jan 30 23:08:40 freenas mps1: Sending reset from mpssas_send_abort for target ID 8
Jan 30 23:08:40 freenas mps1: Unfreezing devq for target ID 8
Jan 30 23:08:40 freenas (probe0:mps1:0:8:0): CAM status: Command timeout
Jan 30 23:08:40 freenas (probe0:mps1:0:8:0): Retrying command
This continues and Freenas does not start up but loops on the errors.
If I pull the SAS cable out of the 380an then the loop ends and FreeNAS boots up.
Anyone have any idea? Any controlcommunication that does not come with the SAS cable? Maybe e so simple that they do not work in this way?
Works to run the 180an with CPU and moterbord with a non HP sas card and get all the disks in FreeNAS, but now as extrernal enclouser.
