Hi, I have a drive that is showing errors, what info do I need to take it back to shop and get an exchange this is what I have so far.
Sunday 3:00am I got this E-Mail
Checking status of zfs pools:
NAME SIZE ALLOC FREE EXPANDSZ FRAG CAP DEDUP HEALTH ALTROOT
freenas-boot 55.5G 1.19G 54.3G - - 2% 1.00x ONLINE -
tank 27.2T 7.88T 19.4T - 6% 28% 1.00x ONLINE /mnt
vol_1 21.8T 2.95T 18.8T - 5% 13% 1.00x DEGRADED /mnt
pool: vol_1
state: DEGRADED
status: One or more devices are faulted in response to persistent errors.
Sufficient replicas exist for the pool to continue functioning in a
degraded state.
action: Replace the faulted device, or use 'zpool clear' to mark the device
repaired.
scan: scrub repaired 0 in 1h57m with 0 errors on Fri Apr 1 05:57:02 2016
NAME STATE READ WRITE CKSUM
vol_1 DEGRADED 0 0 0
raidz2-0 DEGRADED 0 0 0
gptid/79f2d25c-e578-11e5-8e14-00074305cc80 ONLINE 0 0 0
gptid/7cffbe32-e578-11e5-8e14-00074305cc80 ONLINE 0 0 0
gptid/800f7676-e578-11e5-8e14-00074305cc80 FAULTED 6 149 0 too many errors
gptid/831e891c-e578-11e5-8e14-00074305cc80 ONLINE 0 0 0
gptid/863c075e-e578-11e5-8e14-00074305cc80 ONLINE 0 0 0
gptid/89555826-e578-11e5-8e14-00074305cc80 ONLINE 0 0 0
errors: No known data errors
Sunday 8:33 I got this E-Mail
The volume vol_1 (ZFS) state is ONLINE: One or more devices has experienced an unrecoverable error. An attempt was made to correct the error. Applications are unaffected.
Sunday 8:35 I got this E-Mail
The volume vol_1 (ZFS) state is DEGRADED: One or more devices are faulted in response to persistent errors. Sufficient replicas exist for the pool to continue functioning in a degraded state.
Sunday 9:03 I got this E-Mail
Device: /dev/da11 [SAT], ATA error count increased from 5 to 10 The volume vol_1 (ZFS) state is DEGRADED: One or more devices are faulted in response to persistent errors. Sufficient replicas exist for the pool to continue functioning in a degraded state.
Monday 3:00 I got this E-Mail (I had done a Re-Boot Sunday Evening)
freenas.local changes in mounted filesystems:
8c8
< freenas-boot/ROOT/FreeNAS-9.3-STABLE-201602031011 / zfs rw,noatime,nfsv4acls 0 0
> freenas-boot/ROOT/FreeNAS-9.3-STABLE-201604041648 / zfs rw,noatime,nfsv4acls 0 0
freenas.local kernel log messages:
> (da11:mps1:0:13:0): WRITE(10). CDB: 2a 00 4a ea cb 90 00 00 18 00 length 12288 SMID 931 terminated ioc 804b scsi 0 state c xfer 0
> (da11:mps1:0:13:0): WRITE(16). CDB: 8a 00 00 00 00 01 d1 c0 bc a0 00 00 00 e0 00 00 length 114688 SMID 520 terminated ioc 804b scsi 0 state c xfer 0
> (da11:mps1:0:13:0): WRITE(10). CDB: 2a 00 4a ea cc 98 00 00 50 00 length 40960 SMID 562 terminated ioc 804b scsi 0 state c xfer 0
> (da11:mps1:0:13:0): WRITE(16). CDB: 8a 00 00 00 00 01 d1 c0 bc a0 00 00 00 e0 00 00 length 114688 SMID 979 terminated ioc 804b scsi 0 state c xfer 0
> (da11:mps1:0:13:0): WRITE(10). CDB: 2a 00 50 88 1f 18 00 00 08 00
> (da11:mps1:0:13:0): CAM status: SCSI Status Error
> (da11:mps1:0:13:0): SCSI status: Check Condition
> (da11:mps1:0:13:0): SCSI sense: UNIT ATTENTION asc:29,0 (Power on, reset, or bus device reset occurred)
> (da11:mps1:0:13:0): Retrying command (per sense data)
> ipmi0: <IPMI System Interface> port 0xca2,0xca3 on acpi0
> ipmi0: KCS mode found at io 0xca2 on acpi
> ipmi0: IPMI device rev. 1, firmware rev. 3.38, version 2.0
> ipmi0: Number of channels 2
> ipmi0: Attached watchdog
> (da11:mps1:0:13:0): WRITE(10). CDB: 2a 00 98 40 24 a8 00 00 28 00 length 20480 SMID 339 terminated ioc 804b scsi 0 state c xfer 0
> GEOM_ELI: Device da8p1.eli created.
> GEOM_ELI: Encryption: AES-XTS 256
> GEOM_ELI: Crypto: hardware
> GEOM_ELI: Device da0p1.eli created.
> GEOM_ELI: Device da1p1.eli created.
> GEOM_ELI: Device da7p1.eli created.
> GEOM_ELI: Device da3p1.eli created.
> GEOM_ELI: Device da4p1.eli created.
> GEOM_ELI: Device da5p1.eli created.
> GEOM_ELI: Device da6p1.eli created.
> GEOM_ELI: Device ada1p1.eli created.
> GEOM_ELI: Device da2p1.eli created.
> GEOM_ELI: Device da9p1.eli created.
> GEOM_ELI: Device da10p1.eli created.
> GEOM_ELI: Device da11p1.eli created.
> (da11:mps1:0:13:0): READ(10). CDB: 28 00 00 40 00 78 00 00 08 00
> GEOM_ELI: Device da12p1.eli created.
> GEOM_ELI: Device da13p1.eli created.
> GEOM_ELI: Device da14p1.eli created.
> vboxdrv: fAsync=0 offMin=0x312 offMax=0xfe7
> bridge0: Ethernet address: 02:3e:c4:50:92:00
> bridge0: link state changed to UP
> em0: promiscuous mode enabled
> epair0a: Ethernet address: 02:02:29:00:09:0a
> epair0b: Ethernet address: 02:02:29:00:0a:0b
> epair0a: link state changed to UP
> epair0b: link state changed to UP
> em0: link state changed to DOWN
> epair0a: promiscuous mode enabled
> ng_ether_ifnet_arrival_event: can't re-name node epair0b
> em0: link state changed to UP
> epair1a: Ethernet address: 02:f9:85:00:0a:0a
> epair1b: Ethernet address: 02:f9:85:00:0b:0b
> epair1a: link state changed to UP
> epair1b: link state changed to UP
> epair1a: promiscuous mode enabled
> ng_ether_ifnet_arrival_event: can't re-name node epair1b
> (da11:mps1:0:13:0): WRITE(10). CDB: 2a 00 50 98 35 18 00 00 08 00 length 4096 SMID 360 terminated ioc 804b scsi 0 state c xfer 0
> (da11:mps1:0:13:0): WRITE(10). CDB: 2a 00 50 98 35 18 00 00 08 00 length 4096 SMID 352 terminated ioc 804b scsi 0 state c xfer 0
> (da11:mps1:0:13:0): WRITE(10). CDB: 2a 00 50 98 35 18 00 00 08 00 length 4096 SMID 348 terminated ioc 804b scsi 0 state c xfer 0
> (da11:mps1:0:13:0): WRITE(10). CDB: 2a 00 50 98 35 18 00 00 08 00 length 4096 SMID 359 terminated ioc 804b scsi 0 state c xfer 0
> (da11:mps1:0:13:0): WRITE(10). CDB: 2a 00 50 98 35 18 00 00 08 00 length 4096 SMID 368 terminated ioc 804b scsi 0 state c xfer 0
> (da11:mps1:0:13:0): Error 6, Retries exhausted
> (da11:mps1:0:13:0): Invalidating pack
-- End of security output --
freenas-boot 55.5G 1.23G 54.3G - - 2% 1.00x ONLINE -
tank 27.2T 7.75T 19.5T - 6% 28% 1.00x ONLINE /mnt
pool: vol_1
state: DEGRADED
degraded state.
repaired.
gptid/800f7676-e578-11e5-8e14-00074305cc80 FAULTED 6 1 29 too many errors
- End of daily output --
Output from smartctl Monday 11:45
[root@freenas] ~/scripts# smartctl -a /dev/da11
smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p31 amd64] (local build)
Model Family: HGST Deskstar NAS
Device Model: HGST HDN724040ALE640
Serial Number: PK1334PCK3VBES
LU WWN Device Id: 5 000cca 24cec069c
Firmware Version: MJAOA5E0
User Capacity: 4,000,787,030,016 bytes [4.00 TB]
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
ATA Version is: ATA8-ACS T13/1699-D revision 4
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Mon Apr 11 11:10:40 2016 BST
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
data collection: ( 24) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 574) minutes.
SCT capabilities: (0x003d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000b 100 100 016 Pre-fail Always - 0
2 Throughput_Performance 0x0005 137 137 054 Pre-fail Offline - 78
3 Spin_Up_Time 0x0007 126 126 024 Pre-fail Always - 613 (Average 609)
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 19
5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 0
7 Seek_Error_Rate 0x000b 100 100 067 Pre-fail Always - 0
8 Seek_Time_Performance 0x0005 119 119 020 Pre-fail Offline - 35
9 Power_On_Hours 0x0012 100 100 000 Old_age Always - 1653
10 Spin_Retry_Count 0x0013 100 100 060 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 19
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 19
193 Load_Cycle_Count 0x0012 100 100 000 Old_age Always - 19
194 Temperature_Celsius 0x0002 130 130 000 Old_age Always - 46 (Min/Max 18/57)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 10
SMART Error Log Version: 1
ATA Error Count: 10 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Error 10 occurred at disk power-on lifetime: 1627 hours (67 days + 19 hours)
ER ST SC SN CL CH DH
84 51 01 1f 35 98 00 Error: ICRC, ABRT at LBA = 0x0098351f = 9975071
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
61 08 00 18 35 98 40 00 4d+11:15:59.743 WRITE FPDMA QUEUED
ef 10 02 00 00 00 00 00 4d+11:15:59.560 SET FEATURES [Enable SATA feature]
ef 02 00 00 00 00 00 00 4d+11:15:59.560 SET FEATURES [Enable write cache]
ef aa 00 00 00 00 00 00 4d+11:15:59.560 SET FEATURES [Enable read look-ahead]
ef 03 46 00 00 00 00 00 4d+11:15:59.559 SET FEATURES [Set transfer mode]
Error 9 occurred at disk power-on lifetime: 1627 hours (67 days + 19 hours)
61 08 00 18 35 98 40 00 4d+11:15:59.487 WRITE FPDMA QUEUED
ef 10 02 00 00 00 00 00 4d+11:15:59.166 SET FEATURES [Enable SATA feature]
ef 02 00 00 00 00 00 00 4d+11:15:59.166 SET FEATURES [Enable write cache]
ef aa 00 00 00 00 00 00 4d+11:15:59.165 SET FEATURES [Enable read look-ahead]
ef 03 46 00 00 00 00 00 4d+11:15:59.165 SET FEATURES [Set transfer mode]
Error 8 occurred at disk power-on lifetime: 1627 hours (67 days + 19 hours)
61 08 00 18 35 98 40 00 4d+11:15:58.747 WRITE FPDMA QUEUED
ef 10 02 00 00 00 00 00 4d+11:15:58.564 SET FEATURES [Enable SATA feature]
ef 02 00 00 00 00 00 00 4d+11:15:58.563 SET FEATURES [Enable write cache]
ef aa 00 00 00 00 00 00 4d+11:15:58.563 SET FEATURES [Enable read look-ahead]
ef 03 46 00 00 00 00 00 4d+11:15:58.563 SET FEATURES [Set transfer mode]
Error 7 occurred at disk power-on lifetime: 1627 hours (67 days + 19 hours)
61 08 00 18 35 98 40 00 4d+11:15:58.491 WRITE FPDMA QUEUED
ef 10 02 00 00 00 00 00 4d+11:15:58.251 SET FEATURES [Enable SATA feature]
ef 02 00 00 00 00 00 00 4d+11:15:58.251 SET FEATURES [Enable write cache]
ef aa 00 00 00 00 00 00 4d+11:15:58.250 SET FEATURES [Enable read look-ahead]
ef 03 46 00 00 00 00 00 4d+11:15:58.250 SET FEATURES [Set transfer mode]
Error 6 occurred at disk power-on lifetime: 1627 hours (67 days + 19 hours)
61 08 00 18 35 98 40 00 4d+11:15:58.184 WRITE FPDMA QUEUED
60 08 00 18 35 98 40 00 4d+11:15:58.156 READ FPDMA QUEUED
60 08 00 28 fc 79 40 00 4d+11:15:58.138 READ FPDMA QUEUED
60 08 00 28 e7 79 40 00 4d+11:15:58.134 READ FPDMA QUEUED
60 08 00 00 02 7a 40 00 4d+11:15:58.110 READ FPDMA QUEUED
# 1 Short offline Completed without error 00% 1552 -
# 2 Extended offline Completed without error 00% 1439 -
# 3 Short offline Completed without error 00% 1290 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Sorry for the long post I wanted to put as much info as I had.
Any help/pointers would be appreciated
pool: vol_1
state: DEGRADED
degraded state.
repaired.
8c8
pool: vol_1
state: DEGRADED
degraded state.
repaired.
been run.
command.
power-saving mode.
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
