I think I have some errors with my LSI HBA. Everything is fine when I run the system before 11.1 but everything after gives me errors. It looks like my controller randomly disappear and then come back and drives resilver. Here is part of the logs I received in U2 and U3.
Do you think I need new firmware on the controller?
I Installed 11.1-U2 on the March 16th and U3 on March 20th. I went back to 9.10.2-U6 on March 22nd. Since then I have not received any errors, all my logs and scrubs are clean with no resilvering.
Any other ideas? Try U4? I would like to be on 11.1. (I am planning on a getting an additional freenas box and upgrading my network to 10GBase-T switch) and I am looking to utilize some of then new features in 11.1. most notably the Backblaze B2 integration.
(I have been a long time reader of this forum but this is my first post)
Thanks
Michael
ix0: link state changed to UP ix0: link state changed to DOWN ix2: link state changed to DOWN ix2: link state changed to UP ix2: link state changed to DOWN ix2: link state changed to UP ix2: link state changed to DOWN ix2: link state changed to UP ix2: link state changed to DOWN ix2: link state changed to UP mps1: IOC Fault 0x40000d04, Resetting mps1: Reinitializing controller, mps1: Firmware: 20.00.02.00, Driver: 21.02.00.00-fbsd mps1: IOCCapabilities: 1285c<ScsiTaskFull,DiagTrace,SnapBuf,EEDP,TransRetry,EventReplay,HostDisc> mps1: mps_reinit finished sc 0xfffffe0001e84000 post 4 free 3 mps1: SAS Address for SATA device = 859e4e46c8a0d186 mps1: SAS Address from SATA device = 859e4e46c8a0d186 mps1: SAS Address for SATA device = 85984e2fc2c3c484 mps1: SAS Address from SATA device = 85984e2fc2c3c484 mps1: SAS Address for SATA device = 859c5140bdb9ad95 mps1: SAS Address from SATA device = 859c5140bdb9ad95 mps1: SAS Address for SATA device = 859d5f40b2c5af75 mps1: SAS Address from SATA device = 859d5f40b2c5af75 mps1: SAS Address for SATA device = 859e5642a5c3c472 mps1: SAS Address from SATA device = 859e5642a5c3c472 mps1: SAS Address for SATA device = 85985f40bda2d38f mps1: SAS Address from SATA device = 85985f40bda2d38f mps1: SAS Address for SATA device = 859a4739a2bfcf92 mps1: SAS Address from SATA device = 859a4739a2bfcf92 mps1: SAS Address for SATA device = 85984e2fc2a2cf6c mps1: SAS Address from SATA device = 85984e2fc2a2cf6c mps1: SAS Address for SATA device = 859d5b32a3c3d172 mps1: SAS Address from SATA device = 859d5b32a3c3d172 mps1: SAS Address for SATA device = 859d5b32a3a1c587 mps1: SAS Address from SATA device = 859d5b32a3a1c587 mps1: SAS Address for SATA device = 859d54439fa5b17d mps1: SAS Address from SATA device = 859d54439fa5b17d mps1: SAS Address for SATA device = 859d5b32a3b7bd90 mps1: SAS Address from SATA device = 859d5b32a3b7bd90 mps1: SAS Address for SATA device = 859e5b44a5bbaa6f mps1: SAS Address from SATA device = 859e5b44a5bbaa6f mps1: SAS Address for SATA device = 859a4739a2c2cd6f mps1: SAS Address from SATA device = 859a4739a2c2cd6f mps1: IOC Fault 0x40000d04, Resetting mps1: Reinitializing controller, mps1: Firmware: 20.00.02.00, Driver: 21.02.00.00-fbsd mps1: IOCCapabilities: 1285c<ScsiTaskFull,DiagTrace,SnapBuf,EEDP,TransRetry,EventReplay,HostDisc> mps1: mps_reinit finished sc 0xfffffe0001e84000 post 4 free 3 (da22:mps1:0:21:0): Invalidating pack da22 at mps1 bus 0 scbus11 target 21 lun 0 da22: <ATA WDC WD4000FYYZ-0 1K03> s/n WD-WCC136HXY3XJ detached GEOM_MIRROR: Request failed (error=6). da22p1[READ(offset=45031424, length=12288)] GEOM_MIRROR: Device swap4: provider da22p1 disconnected. GEOM_ELI: g_eli_read_done() failed (error=6)g_access(918): provider da22 has error 6 set mirror/swap4.eli[READ(offset=74575872, length=40960)] swap_pager: I/O error - pagein failed; blkno 2115363,size 40960, error 6 vm_fault: pager read error, pid 4776 (zfsd) g_access(918): provider da22 has error 6 set g_access(918): provider da22 has error 6 set g_access(918): provider da22 has error 6 set g_access(918): provider da22 has error 6 set g_access(918): provider da22 has error 6 set g_access(918): provider da22 has error 6 set g_access(918): provider da22 has error 6 set mps1: SAS Address for SATA device = 859e4e46c8a0d186 mps1: SAS Address from SATA device = 859e4e46c8a0d186 mps1: SAS Address for SATA device = 85984e2fc2c3c484 mps1: SAS Address from SATA device = 85984e2fc2c3c484 mps1: SAS Address for SATA device = 859d5f40b2c5af75 mps1: SAS Address from SATA device = 859d5f40b2c5af75 mps1: SAS Address for SATA device = 859e5642a5c3c472 mps1: SAS Address from SATA device = 859e5642a5c3c472 mps1: SAS Address for SATA device = 859c5140bdb9ad95 mps1: SAS Address from SATA device = 859c5140bdb9ad95 mps1: SAS Address for SATA device = 85985f40bda2d38f mps1: SAS Address from SATA device = 85985f40bda2d38f mps1: SAS Address for SATA device = 859a4739a2bfcf92 mps1: SAS Address from SATA device = 859a4739a2bfcf92 mps1: SAS Address for SATA device = 85984e2fc2a2cf6c mps1: SAS Address from SATA device = 85984e2fc2a2cf6c mps1: SAS Address for SATA device = 859d5b32a3c3d172 mps1: SAS Address from SATA device = 859d5b32a3c3d172 mps1: SAS Address for SATA device = 859d5b32a3a1c587 mps1: SAS Address from SATA device = 859d5b32a3a1c587 mps1: SAS Address for SATA device = 859d54439fa5b17d mps1: SAS Address from SATA device = 859d54439fa5b17d mps1: SAS Address for SATA device = 859d5b32a3b7bd90 mps1: SAS Address from SATA device = 859d5b32a3b7bd90 mps1: SAS Address for SATA device = 859e5b44a5bbaa6f mps1: SAS Address from SATA device = 859e5b44a5bbaa6f mps1: SAS Address for SATA device = 859a4739a2c2cd6f mps1: SAS Address from SATA device = 859a4739a2c2cd6f (da22:mps1:0:21:0): Periph destroyed da22 at mps1 bus 0 scbus11 target 21 lun 0 da22: <ATA WDC WD4000FYYZ-0 1K03> Fixed Direct Access SPC-4 SCSI device da22: Serial Number WD-WCC136HXY3XJ da22: 600.000MB/s transfers da22: Command Queueing enabled da22: 3815447MB (7814037168 512 byte sectors) mps1: IOC Fault 0x40000d04, Resetting mps1: Reinitializing controller, mps1: Firmware: 20.00.02.00, Driver: 21.02.00.00-fbsd mps1: IOCCapabilities: 1285c<ScsiTaskFull,DiagTrace,SnapBuf,EEDP,TransRetry,EventReplay,HostDisc> mps1: mps_reinit finished sc 0xfffffe0001e84000 post 4 free 3 mps1: SAS Address for SATA device = 859e4e46c8a0d186 mps1: SAS Address from SATA device = 859e4e46c8a0d186 mps1: SAS Address for SATA device = 85984e2fc2c3c484 mps1: SAS Address from SATA device = 85984e2fc2c3c484 mps1: SAS Address for SATA device = 859c5140bdb9ad95 mps1: SAS Address from SATA device = 859c5140bdb9ad95 mps1: SAS Address for SATA device = 859d5f40b2c5af75 mps1: SAS Address from SATA device = 859d5f40b2c5af75 mps1: SAS Address for SATA device = 859e5642a5c3c472 mps1: SAS Address from SATA device = 859e5642a5c3c472 mps1: SAS Address for SATA device = 85985f40bda2d38f mps1: SAS Address from SATA device = 85985f40bda2d38f mps1: SAS Address for SATA device = 859a4739a2bfcf92 mps1: SAS Address from SATA device = 859a4739a2bfcf92 mps1: SAS Address for SATA device = 85984e2fc2a2cf6c mps1: SAS Address from SATA device = 85984e2fc2a2cf6c mps1: SAS Address for SATA device = 859d5b32a3c3d172 mps1: SAS Address from SATA device = 859d5b32a3c3d172 mps1: SAS Address for SATA device = 859d5b32a3a1c587 mps1: SAS Address from SATA device = 859d5b32a3a1c587 mps1: SAS Address for SATA device = 859d54439fa5b17d mps1: SAS Address from SATA device = 859d54439fa5b17d mps1: SAS Address for SATA device = 859d5b32a3b7bd90 mps1: SAS Address from SATA device = 859d5b32a3b7bd90 mps1: SAS Address for SATA device = 859e5b44a5bbaa6f mps1: SAS Address from SATA device = 859e5b44a5bbaa6f mps1: SAS Address for SATA device = 859a4739a2c2cd6f mps1: SAS Address from SATA device = 859a4739a2c2cd6f -- End of security output --
Thanks
Michael
