I'm in a bit of a pickle.
I've had a vm running for about a year now. it is running exactly the way I want it to run.
However as the year have been going I've been updating applications and installing new things, ETC you know once you have a server you start using it for every unthinkable things you can find along the way.
However now I've run out of space. which is odd as I gave it about 1tb space to begin with.
However when I go to the VM and run the df -h command I can see that it was never 1 tb in size it is only about a mere 120gb in size.
So this is where I am. I've been trying various methods of stopping the VM and trying to change the zvol to 2 TB however it just doesn't change when I start it all up again. I can't remember how I setup the Zvol to begin with.
I might have made it change dynamically but It doesn't seem to be working.
So here I am hoping anyone here could give me a pointer to what I'm doing wrong. or what I should be doing ?
if my thought is correct that it is dynamically changing then how do I remake it so that the size is fixed at 1TB ?
in advance thanks for your time.
