SOLVED VM Using More Storage than what's Allocated
Zain
I've encroached the 80% limit, hell, I've encroached 90% and am trying to free up some disk space while I wait for my larger drives to show up later in the week.
Can anyone help me determine why the zvol "used" storage for the VM is more than double the capacity of the size for the zvol? Refer to the image below. "Size for the zvol*" is set to 1000GB but it is using 2.39TB?
TIA!
ClassicGOD
Snapshots?
Zain
Snapshots?
Yup! Without spending any time in the manual, I was under the impression that deleting snapshots would delete snapshots. I had to go to storage >> snapshot and manually delete the files. Thanks.
