ESXi > Scale
melloa
Hi folks,
I'm testing virtualization on Scale and seems to be working fine; creating, cloning, auto start, all good so far. Even a Win11 VM installed without any issues:
Has anyone converted ESXi VMs to Scale? I imagine step 1 would be convert the VMKD disk to a compatible format - not sure as I see zvols created for each VM, so assume those are the disks (?)
If someone can direct me to some docs for my reading pleasure I'd appreciate.
Thanks!
Kris Moore
SVP of Engineering
Administrator
You'd need to convert VMDK -> RAW and then if you want to use ZVols, you'd upload the RAW file and "dd" it to the zvol in question.
# dd if=<path to RAW filel> of=/dev/zvol/tank/virtual_machines/ubuntu20-XXXX
Something like that :)
melloa
melloa
So far: ubuntu worked
  • Migrate VM from ESXi to TrueNAS Scale.pdf
melloa
Finished a windows 10 VM migration and no issues. Windows found the new hardware (the NIC), configured at boot and got an IP from my DHCP.
Just one thing ... is dd this slow?
scale# dd if=/mnt/tank/cifs/repository/pernambuco.img of=/dev/zvol/tank/virtual_machines/pernambuco
134217728+0 records in
134217728+0 records out
68719476736 bytes (69 GB, 64 GiB) copied, 6107.84 s, 11.3 MB/s
Mlovelace
You could/should adjust the block size of the dd command for better write performance. bs=64K is an okay start but there are scripts that can test for the optimal.
For your reading pleasure.
speedtriple
This is interesting.
So TrueNAS Scale can replace my ESXi running TrueNAS Core as VM?
And then run my W10 and my other few VM's just as good under TrueNAS Scale instead?
That would be just awsome!!
melloa
I'd say yes.
Today I run all my TrueNASes as VMs under ESXi. Just need to understand what's the back-ups available for Scale.
speedtriple
I am using ESXi Free. Backing up VM's manually with Spidsoft, works great but not automatic and not warm.
And the ESXi usb-boot must manually have a dd-backup.
So it is the backup possibilty I see with TrueNAS Scale, for the VM's, and the whole setup.
ESXi just works 100%, so if TrueNAS Scale delivers... could be awsome.
rexit1982
The real trick....getting esxi to run as a VM on Scale/kvm. esx 7.x doesn;t ahve e1000 or libvrt nic drivers so it will not install. 6.7 PSoDs... started looking into it at one point but gave up and have not gotten back to it.
speedtriple
That sounds more like The Matrix(?) :)
theprez
How did you get Ubuntu working - which of the 3 selections under Guest Operating System under Create Virtual Machine did you use? All I see is Windows, FreeBSD and Linux?
This is on the latest RC of Scale in case that matters.
Thanks
melloa
Thanks
ubuntu = linux flavor.
jamesjfa
@rexit1982
did you ever get ESX nested in SCALE? I want to keep an VMware lab if I can for testing and training. Ideally I can move over to SCALE bare metal rather than a VM with a SAS controller passed through to it.
