TrueNAS SCALE VMs not launching
bdgusa
Hi there,
I've struggled for a while with getting VMs to launch on SCALE. Docker/K8s/Helm works fine with Apps, storage, networking, etc. all work.
When I go to launch a VM, irrespective of the OS (both install ISOs in the VM storage location), and irrespective of UEFI or Legacy BIOS, nothing happens. If I try to download logs, the file is empty. Serial console just hangs at "Connected to domain 'vmname'" with no interactive console.
If I launch without an ISO attached, I can interact with the serial console and the boot menu.
I'm a little lost on where to go next.
Searching for the VM name in the logs:
/var/log/syslog:Jun 9 07:22:12 truenas1 middlewared[1175]: libvirt: QEMU Driver error : Domain not found: no domain with matching name '1_test'
/var/log/syslog:Jun 9 07:23:19 truenas1 systemd[1]: Started Virtual Machine qemu-1-1test.
If I tail /var/log/middlewared.log while creating and starting new VM, ISO attached (now from different data location from the VM):
[2022/06/09 07:34:16] (DEBUG) VMDeviceService.update_device():106 - Creating ZVOL data/vm/newvm-d7tcua with volsize 32212254720
[2022/06/09 07:34:32] (DEBUG) middlewared.__set_guest_vmemory():22 - Setting ARC from 101388576768 to 97093609472
usr/lib/python3/dist-packages/middlewared/plugins/vm/vm_lifecycle.py:105: RuntimeWarning: coroutine 'accepts.<locals>.wrap.<locals>.nf' was never awaited
self.start(id, {'overcommit': True})
RuntimeWarning: Enable tracemalloc to get the object allocation traceback
[2022/06/09 07:36:52] (DEBUG) VMService.teardown_guest_vmemory():53 - Giving back guest memory to ARC: 101388576768
The /mnt/data/vm directory is empty. No VMs there.
Searching the filesystem for "*newvm*" yields:
  • VM config in /etc/libvirt/qemu/1_newvm.xml
  • /dev/data/vm/newvm-d7tcua
  • /dev/zvol/data/vm/newvm-d7tcua
  • /var/db/system/syslog-XXXX/log/libvirt/qemu/1_newvm.log
The last entry (log) contains:
2022-06-09 14:34:39.480+0000: starting up libvirt version: 7.0.0, package: 3 (Andrea Bolognani <eof@kiyuko.org> Fri, 26 Feb 2021 16:46:34 +0100), qemu version: 5.2.0Debian 1:5.2+dfsg-11+deb11u1, kernel: 5.10.93+truenas, hostname: truenas1.local
LC_ALL=C \
PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin \
HOME=/var/lib/libvirt/qemu/domain-1-1_newvm \
XDG_DATA_HOME=/var/lib/libvirt/qemu/domain-1-1_newvm/.local/share \
XDG_CACHE_HOME=/var/lib/libvirt/qemu/domain-1-1_newvm/.cache \
XDG_CONFIG_HOME=/var/lib/libvirt/qemu/domain-1-1_newvm/.config \
QEMU_AUDIO_DRV=none \
/usr/bin/qemu-system-x86_64 \
-name guest=1_newvm,debug-threads=on \
-S \
-object secret,id=masterKey0,format=raw,file=/var/lib/libvirt/qemu/domain-1-1_newvm/master-key.aes \
-machine pc-i440fx-5.2,accel=kvm,usb=off,dump-guest-core=off,memory-backend=pc.ram \
-cpu SandyBridge \
-m 4096 \
-object memory-backend-ram,id=pc.ram,size=4294967296 \
-overcommit mem-lock=off \
-smp 2,sockets=1,dies=1,cores=2,threads=1 \
-uuid 614a47c4-e277-4903-8678-448e1bfe8e8f \
-no-user-config \
-nodefaults \
-chardev socket,id=charmonitor,fd=32,server,nowait \
-mon chardev=charmonitor,id=monitor,mode=control \
-rtc base=localtime \
-no-shutdown \
-boot strict=on \
-device nec-usb-xhci,id=usb,bus=pci.0,addr=0x4 \
-device ahci,id=sata0,bus=pci.0,addr=0x5 \
-device virtio-serial-pci,id=virtio-serial0,bus=pci.0,addr=0x6 \
-blockdev '{"driver":"file","filename":"/mnt/data/iso/ubuntu-20.04.4-live-server-amd64.iso","node-name":"libvirt-2-storage","auto-read-only":true,"discard":"unmap"}' \
-blockdev '{"node-name":"libvirt-2-format","read-only":true,"driver":"raw","file":"libvirt-2-storage"}' \
-device ide-cd,bus=sata0.0,drive=libvirt-2-format,id=sata0-0-0,bootindex=1 \
-blockdev '{"driver":"host_device","filename":"/dev/zvol/data/vm/newvm-d7tcua","node-name":"libvirt-1-storage","cache":{"direct":true,"no-flush":false},"auto-read-only":true,"discard":"unmap"}' \
-blockdev '{"node-name":"libvirt-1-format","read-only":false,"cache":{"direct":true,"no-flush":false},"driver":"raw","file":"libvirt-1-storage"}' \
-device ide-hd,bus=sata0.1,drive=libvirt-1-format,id=sata0-0-1,bootindex=2,write-cache=on \
-netdev tap,fd=36,id=hostnet0,vhost=on,vhostfd=37 \
-device virtio-net-pci,netdev=hostnet0,id=net0,mac=00:a0:98:2b:e0:6e,bus=pci.0,addr=0x3 \
-chardev pty,id=charserial0 \
-device isa-serial,chardev=charserial0,id=serial0 \
-chardev spicevmc,id=charchannel0,name=vdagent \
-device virtserialport,bus=virtio-serial0.0,nr=1,chardev=charchannel0,id=channel0,name=com.redhat.spice.0 \
-device usb-tablet,id=input0,bus=usb.0,port=1 \
-vnc 0.0.0.0:0 \
-device qxl-vga,id=video0,ram_size=67108864,vram_size=67108864,vram64_size_mb=0,vgamem_mb=16,max_outputs=1,xres=1024,yres=768,bus=pci.0,addr=0x2 \
-device virtio-balloon-pci,id=balloon0,bus=pci.0,addr=0x7 \
-sandbox on,obsolete=deny,elevateprivileges=deny,spawn=deny,resourcecontrol=deny \
-msg timestamp=on
char device redirected to /dev/pts/0 (label charserial0)
2022-06-09T14:36:51.542398Z qemu-system-x86_64: terminating on signal 15 from pid 2287222 (/usr/sbin/libvirtd)
2022-06-09 14:36:51.743+0000: shutting down, reason=destroyed
TrueNAS SCALE Version: 22.02.0.1 (Platform Generic)
Hardware:
Dell R620 with flashed H710.
2x Intel(R) Xeon(R) CPU E5-2660 0 @ 2.20GHz
bdgusa
This is what happens if I try to download logs via the UI:
2022/06/09 08:15:12] (ERROR) middlewared.job.run():424 - Job <bound method accepts.<locals>.wrap.<locals>.nf of <middlewared.plugins.filesystem.FilesystemService object at 0x7fc9dbdd8880>> failed
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 412, in run
await self.future
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 448, in __run_body
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1261, in nf
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1129, in nf
res = await f(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/plugins/filesystem.py", line 364, in get
raise CallError(f'{path} is not a file')
middlewared.service_exception.CallError: [EFAULT] /var/log/libvirt/bhyve/1_newvm.log is not a file
I've also just updated TrueNAS SCALE to the latest available.
rich45
Gentlemen
rich here struggling with vm's not booting after install if I have read correctly the grub is not transferring or persistent to hard drive. this is occurring with all linux vm's
using
TrueNAS-SCALE-22.02.4
is there a easy way around this. sorry if I have not left enough information. hopefully you understand what I mean.
thank you
rich45
soleous
I know this might be silly questions because it looks like you know what you're doing, but is virtualization enabled on the hardware, like VT-d.
Also, you won't see a folder under your VM directory as it's a block-level volume, but you will see it within the 'zfs list' as you do within dev.
Edit: just noticed, this is an old thread. rich45, we need more information, I'd recommend creating a new thread rather than reviving an old thread, that doesn't look like its related to your issue.
Basserra
Gentlemen
using
thank you
rich45
Hey Rich, I had this same problem. Linux VMs boot broken while Windows VMs were fine. But, please note I only use Debian VMs on TN Scale; I have not tested with Arch or RHEL (these on proxmox w/no issues).
I looked into fixing grub and came across this https://help.ubuntu.com/community/Boot-Repair I tried to fix it myself with no results, but just chucking in the Boot-Repair-Disk to the VMs 'CD-ROM' and using the auto/recommended fix repaired them nicely and now they all boot properly.
Give it a shot and good luck!
